Tein EDFC Kit - searching for install tips for an NB8B
- Vehicle: ND - 2
how the flower do you get the wires from the front shocks into the cabin.
Pics would be a help too.
Thanks
SPy
Thanks
SPy
- 16bit
through the fire wall. there should be some wires going into the cabin anyway so I would just use the same hole.
here is a little info.
http://www.clubroadster.net/forum/viewt ... light=edfc
like they say make sure you tape the wires to an old coat hanger to make it easy to push through and find the wires again. sorry no pics mate.
- Vehicle: ND - 2
Thanks 16bit,
On the left side of the firewall there is a loom that goes through, there is a nipple (99MXV titters) which is where the bonnet release runs through on the drivers side, I cut that off and threaded some light weight weed whacking line through it, hooked it out on the cabin side with a coat hanger.
ample use of some lecco tape and a bit of space between both bits of wire and then pulled it all back into the engine bay.
The tip about the gaping hole behind the drivers seat is soooooooo true.
Took about 5 minutes to do the rear, just threaded a whack of line through the hole into the boot, fished it out, more lecco tape and pull it back the other way.
Presto, the difficult bits are done.
A bit more tinkering tomorrow night and it should be done.
So when do I get a test drive?
Glad you got it sorted I could have taken some pics of my setup. I'll be interested to see where you decide to stick the control unit.
- Vehicle: ND - 2
Wiring is in and the motors are on.
A quick bodgy wire up and Whirrrrrrrrrr,
set the three memories up to super soft, half, and full hard.
Whirr, Whiirrrrrrrrr, whir, whirrrrrrrrrrrrrrrrrrrr, whirrrrrrr, then left them on half and pulled bits of it apart till it all gets wired in all neat and proper.
Beer Time . . .
I've even scored a spare console with not broken bits (Thanks CT), so after it all gets scrubbed up and put back in, the car will be back together fully for the first time in three years.
Beer Time . . .
Nice work SPy! Glad the motors were installed correctly
Just arrived home, left yours 2 hours ago... BIG smash on the freeway top of the hill at Nerang, highway closed, Police by the hundreds...
- Vehicle: ND - 2
NMX516 wrote:Nice work SPy! Glad the motors were installed correctly
As suspected the motors wound all the way down, we forgot that unscrewing the ratchet bit also unscrews the bit underneath, it all makes sense now . . . (kinda)
Should be able to whip yours and Unicorns in, in enough time to be done before the first batch of wingszzz finish
bugger about the crash.
- Vehicle: ND - 2
All Done,
Even got the console as well as the boot lining back in, didn't know myself climbing in, there's a big chunk of plastic for your left arm now.
Only one last thing to do and were sorted for another 100K.
Took the bodgy way out and put the EDFC controller in the cubby hole thing, luckily I have a spare if I change my mind.
- AJ
SPy vs. SPy wrote:
Even got the console as well as the boot lining back in.
XMX5 Rogues
- Vehicle: ND - 2
the console is back in??
Yep, new modern technology called "Phillips Head Screwdriver" was used to perform a "cupholderectomy" and "lidlockerworkerology".
Further use of this magic tool resulted in a "consoleinthecarinstallcantbelieveitstrueectomy"
- Tezzax5
SPy vs. SPy wrote:NMX516 wrote:Nice work SPy! Glad the motors were installed correctly
Should be able to whip yours and Unicorns in, in enough time to be done before the first batch of wingszzz finish![]()
1...cable's installed
2...edfc installed
3.. SS still to be installed....Maybe during the week if i get time?
SPy is there any chance of seeing the install in the console?
Looks to me like the EDFC install should be fairly easy. I'm going to mount the controller in the glove box, but on the flat panel at the top of the glove box, not actually inside the box itself, if that makes sense... If not, go out to your car and have a look
- mazlot
You guys will never go any faster if you keep adding weight to the car
Farken Gruven
bah, anyone can go faster by reducing weight. The REAL challenge is in going faster but adding weight!
I'd love to add one of those heavy turbos and that self indulgent weight of intercooling the charge
