Patchy's Fawlty Towers risk management. Enter at own risk
- StanTheMan
I had 2 L all up. Buy at least 3L...... gives you room for error & the learning curve.
make sure you have heaps of primer on it too. & make sure you do at least 2 full guide coats
what I mean is 3coats of primer.
1 guide coat
another 2 or 3 coats of primer
another guide coat
then let loose with the real paint
good luck
1 guide coat
another guide coat
good luck
- kitkat
StanTheMan wrote:I had 2 L all up. Buy at least 3L...... gives you room for error & the learning curve.
1 guide coat
another guide coat
good luck
Cheers mate, i didnt have a clue on how much i would need
From what i've read you can't get a better base than factory paint... so basically i dont need primer unless i have bare metal exposed in which case ill need to etch, sand then add primer. A must when sending over factory paint is make sure its all scuffed up so the new paint grabs.
So basically what i think im going to do is sand off the clear coat (which is currently whats causing all the problems (burning and flaking). lightly sand the paint underneath then start spraying over.
With any luck she'll have a fresh new coat in a couple months
- jules
- Guitar Hero
- StanTheMan
- StanTheMan
Patchy's Labour of love
Patchy is Back.
Despite all the good intentions of Bigdog & Stan's hard work last year. She's getting another paint job.
This time. Classic Red in 2 pack.
Unfortunatlely because the previous paint has trapped water in it It all needs to come off first. So that means The acrylic as well as the primer underneath. Some panels will be partially back to meyal. Others totally.
Patchy's paint job Continues
these are not archived pics......These are current.
This morning
a little while later
This morning
Looks like a photoshop....
- StanTheMan
Moto wrote:Looks like a photoshop....
allow me assure you.....its not.
the bonnet looks as though it may ave had hail damage at one stage or another. This didn't appear when I sanded it back by hand.
Pics to follow.
Keep it silver to match your hair
- StanTheMan
Okibi wrote:Keep it silver to match your hair
Chuckle , chuckle...... Craigy Owns that line
Kind of looks like hail damage? do you think?
interestingly enough......this didn't really appear when I sanded it back in 2006 by hand or last year.
This time I'm using a orbital sander
in 2006
StanTheMan wrote:This time I'm using a orbital sander..
You gotta stop holding it in the one spot too long.
So are you sticking with classic red?
I was thinking about SE red for my NA .. or black.
- StanTheMan
Classic Red.
I love Jade Monkeys Camry Blue.....but its a bit Ghey.
Do a comparison photo - put the bonnet against the fence and we can see how tall your boy has grown!
- Craig
- Vehicle: Non MX-5
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
