how to tell if it's a 1.8?
SKYHI
Postby SKYHI » Sun Apr 05, 2009 2:17 pm
Hey Guys,
Never having seen a 1.6 engine, is there an easy way to tell the difference between the 1.6 and 1.8?
Thanks, Paul.
StanTheMan
Postby StanTheMan » Sun Apr 05, 2009 2:44 pm
The cam cover is a little different. On the pic below you can see Mazda & twin cam. recesses into the Cam cover.
1.8's are the other direction. rather raised instead of recessed. Clear as mud?
Also to the right you will see the Grey thingy. Just after ( or just before) the Mania CAI. This is the 1.6 AFM. The BP one is black & a lot smaller.
If you are only looknig at the engine only. At the back of the head or somewhere you will see big B6 or BP letters.
SuperMazdaKart
Postby SuperMazdaKart » Sun Apr 05, 2009 2:55 pm
1.6 left, 1.8 right
CAS on the intake cam for 1.6, CAS on exhaust cam for 1.8,
1.6 has the vane type AFM, 1.8 has an MAF,
1.6 cam cover has recessed writing, 1.8 doesn't,
1.6 engine number will start with a B6 & 1.8 starts with a BP
mr_rotary
Postby mr_rotary » Mon Apr 06, 2009 8:51 pm
1.6 has coils on the right with a shroud.
1.8 has coils on the left
Opposite to the CAS :mrgreen:
whoa_dang_96
Postby whoa_dang_96 » Thu Apr 09, 2009 12:14 pm
not all 1.6 have the coil and CAS in the config shown - maybe the 90-92 model could be this specific
you can get a 1.6 with raised writing on the rocker cover (or a rocker cover off a different model Mazda does fit), CAS on the exhaust CAM etc you just need to look at the "market" that the mx5 was was sold in and the engine cofigurations available.
I have seen it before .... and yes you can get 1.6 BP's
mx52nv
Purple Porsche Eater
Postby mx52nv » Thu Apr 09, 2009 6:45 pm
whoa_dang_96 wrote:not all 1.6 have the coil and CAS in the config shown - maybe the 90-92 model could be this specific
Hmmm I have never seen a MX5 B6 1.6 with the CAS on the exhaust side or a '1.6' BP before??? After all, BP is the designated name for the 1.8 engine from Mazda that powered all the Familias/Astinas/MX5s.
I have seen a NB8 with a B6 though, as sold in Singapore and a few other markets. But definitely not a '1.6' BP. :?
project.r.racing
Postby project.r.racing » Thu Apr 09, 2009 10:02 pm
just look on the block, it'll either have B6 or BP on it...
or look at the engine number, 1.6s start with B6, 1.8s start with BP...
