Nube question how do I RAISE UP my car?
wun911
Postby wun911 » Mon Apr 06, 2009 6:26 pm
I have coilovers...
Do I move the spring perch (the purple collar in the pic) up or down to RAISE UP the car.
Need to raise up the car heaps to get it up on ramps.
Thanks in advance sorry for the nube question.
every ounce counts
NMX516
Postby NMX516 » Mon Apr 06, 2009 6:58 pm
Up :wink:
p.s, can you drive the car up onto a block of wood or a paver or something to get another inch in height? easier than raising the suspension....
marcusus
Postby marcusus » Mon Apr 06, 2009 7:00 pm
Just take the collar off. Saves weight :wink:
I'm surprised you painted your calipers. I thought that'd add weight as well.
My trolley jack doesn't fit under the car, so what I do is use the scissor jack to lift it a bit, then wheel the trolley jack in and go from there. Sure beats raising the suspension each time.
Postby Jeo » Mon Apr 06, 2009 7:15 pm
marcusus wrote:I'm surprised you painted your calipers. I thought that'd add weight as well.
I was thinking the exact same thing :D
marcusus wrote:My trolley jack doesn't fit under the car, so what I do is use the scissor jack to lift it a bit, then wheel the trolley jack in and go from there. Sure beats raising the suspension each time.
If someone else is around I just get them to lift the car up a little. There's enough play in my suspension to then get my smaller trolley jack under it.
wun911
Postby wun911 » Mon Apr 06, 2009 7:15 pm
Hrmz I cant raise it UP all that much...
every ounce counts
de Bounce
Postby de Bounce » Mon Apr 06, 2009 7:24 pm
I made a pair of low ramps which raises the front up so the jack fits under
Used some wood and about 1/2 hour
Motorkhana Video
Users browsing this forum: Google [Bot] and 146 guests
