Do I move the spring perch (the purple collar in the pic) up or down to RAISE UP the car.
Need to raise up the car heaps to get it up on ramps.
Thanks in advance sorry for the nube question.
marcusus wrote:I'm surprised you painted your calipers. I thought that'd add weight as well.
marcusus wrote:My trolley jack doesn't fit under the car, so what I do is use the scissor jack to lift it a bit, then wheel the trolley jack in and go from there. Sure beats raising the suspension each time.
