Amp Placement
Amp Placement
Postby Regie » Mon Apr 06, 2009 6:20 pm
So ive finially decided to upgrade the speakers in the 5
i bought some JL audio 6.5in splits (great sound for the 400 i paid, these retail at 799), and a Kicker 2 Chanel Amp.
Now the ideal place for the amp would be behind the passenger seat about half way up the firewall. That way the seat base can still go right back just with the recline a tad more upright. I tend to use my boot a fair bit and fill it right up, so id like to keep the boot space free.
I assume there are several people on here with the amp mounted in the said position. My main concern would be heat from the amp. Do you think there would be enough air circulation around the amp to stop it from overheating? How have other people come across this?
The amp wont be running at full power and also wont be powering a sub.
Any comments.
Cheers in advance
Locutus
Amp Placement
Postby Locutus » Mon Apr 06, 2009 6:33 pm
if you're not going to run it at full power heat will never be a problem. mine is behind the driver's seat and only gets warm (~40C), never hot.
Amp Placement
Postby Jeo » Mon Apr 06, 2009 6:45 pm
I'm assuming NA/NB, in which case this should help.
I've currently got the brain box for my head unit mounted there and have no problems with it. When it first went in I made sure the seat back never touched it and checked it by hand every other drive, saw no problems with heat so pushed the seat all the way back. Continued monitoring it for about a fortnight and it seemed fine so I left it alone. Has been like that for 6-9months now and hasn't caused any concern.
Long story short, I wouldn't worry about it.
Amp Placement
Postby Regie » Mon Apr 06, 2009 7:16 pm
yeah NB8B
ive read most of the topics in this section and yeah looks like i dont have to worry about it..
Bring on the sound i say!
Kain
Amp Placement
Postby Kain » Tue Apr 07, 2009 6:49 pm
Hey, that's my amp setup in the thread Jeo referenced. Just chiming in to say its been there a month now and I've had no heat issues at all.
Just be careful with the install and you'll be fine. Best of luck!
Amp Placement
Postby Okibi » Wed Apr 08, 2009 1:23 am
Here's mine, only a lil cheap and cheerful clarion
daffyflyer
Amp Placement
Postby daffyflyer » Wed Apr 08, 2009 2:33 pm
Pah.. Look at all that weight - Take that amp out or you'll make wun angry! :mrgreen:
Amp Placement
Postby Okibi » Wed Apr 08, 2009 2:58 pm
Just takes 2 wing nuts and a few plugs and all that weight comes right out. :mrgreen:
daffyflyer
Amp Placement
Postby daffyflyer » Wed Apr 08, 2009 3:39 pm
Okibi wrote:Just takes 2 wing nuts and a few plugs and all that weight comes right out. :mrgreen:
True true, but when you put it back in, I imagine Wun feels a disturbance in the force...
