Szemen wrote:Go n/a!!! mmmm! imagine a 8k screamer! get ITRBs later on
Yeah, I sold out
If I could afford a full all out NA motor I would, but turbo just looks too good
adamjp wrote:I couldn't speak to the strength of the stock pistons as I've never run a turbo on my engine. For your BP engine you can get ACL pistons for a turbo BP for around $500 within this country. Talk to Greg at ProEngines (or your engine builder) about what he would sell them for.
You might want to have a lurk around turbomiata.net
You will find that plenty of guys in the US have used the Belfab rods to good effect in turbo MX5 engines. I can arrange a good deal for you on a set of them.
I'd be surprised if a simple turbo build would set you back $6k, particuarly with you doing the spanner work.
Juffa wrote:As already suggested get yourself onto miataturbonet and do some research. They have a very comphrehensive FAQ section. Make sure you read that before posting any questions as they will tear you a new one for any 'newb' questions.
The amount of boost that a stock engine can handle is based on a lot of variables. Flyin' Miata state 12 pounds is about the limit, but there there are people out there running high levels. Things such as fuel management, timing, intake temps and so forth all need to be considered.
The setup I have was recorded at 122Kw at the wheels by the previous owner running 9 pounds of boost. I have made several changes since then, but have not had her on a dyno to tweek the tuning.
J
