Goodies getting fitted! :)
Craig
Postby Craig » Sat Mar 21, 2009 9:53 am
Wonder what I can expect performance wise with these fitted? :mrgreen:
Throttle body inlet pipe for SE MX-5
SE Intercooler upgrade kit
blackster
Postby blackster » Sat Mar 21, 2009 11:34 am
Craig wrote:Wonder what I can expect performance wise with these fitted? :mrgreen:
Those "goodies" should be considered as items that prevent or reduce performance. IE Loss of power due to heatsoak (OEM IC) & loss of boost (pressure drop or in severe circumstances no boost at all as the rubber TBi has gone woopsies)
The greatest gain will come from changing the air intake and exhaust. There is nothing from stopping you from turning up the boost manually other than boost cut @ 10.5 psi; although you will be sucking and blowing through a straw if you do with the OEM exhaust & air intake.
Be mindful of using a larger IC with the OEM air intake/exhaust as you may experience a small drop in boost.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Fuzzlet
Postby Fuzzlet » Mon Mar 23, 2009 4:06 pm
As blackster said, you probably wont notice much of an increase until you do the intake and exhaust. Once you do you'll gain a solid 30rwkw or so. Having said that I'm sure you're gonna enjoy your modified car haha :P
Postby Okibi » Mon Mar 23, 2009 10:42 pm
Congrats Craig, looks like a nice upgrade.
Craig
Postby Craig » Wed Mar 25, 2009 12:22 pm
Bugger, I'm kinda happy not to do the exhaust and intake to be honest! :wink:
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed Mar 25, 2009 12:53 pm
Just do the exhaust, it's a good upgrade...if you do the intake then you end up needing a ECU and it all gets too complicated.
Sean
Postby Sean » Tue May 26, 2009 11:06 pm
Sell the car, get a 13bt s1 rx7...
Happy I'm back?
Users browsing this forum: No registered users and 225 guests
