Clubman: 14's or 15's ?
- Learner Driver
- Vehicle: ND - 2
Semi slick tyres tend to be cheaper in 14 inch. I would go with the cheapest option. I've used Toyo Proxes RA1 in 14 inch and Toyo Proxes R888 in 15 inch. There was no benefit in using the 15 inch tyre, just more money spent.
- Hammer
It also depends on what class you're to trying to compete against.
If you would like to compete on "Class 1" (l.e. factory stock standard), then you'll need to get the same size wheels as the OEMs (14x5.5). But if you'd like to be in modified class....most people go for 15" wheels, mostly due to the cost of the tyres.
the oem clubman wheels are 14 x 6 iirc, the na6 wheels are 14 x 5.5 .
i use the clubman wheels as my track rims, with r888's. works fine for me. i had 15s previously, i haven't noticed any negatives in going down in size.
- Hammer
Fatty wrote:the oem clubman wheels are 14 x 6 iirc, the na6 wheels are 14 x 5.5 .
I stand corrected. You're absolutely right. I don't know how I got this mixed up. I run a Clubman in Class 1 during track days, so I should know this to heart.
dorbar wrote:I have seen sets of 14x5.5 around, but not the Clubman 14x6........ are they easy to find / get?
You don't have to get the factory NA8 wheels to be in class 1. So long as it's a 14x6, it will do. Though having said that the OEM 14x6 on the NA8 are very light.
the clubman rims do come up for sale on this forum occasionally. thats how i got mine. i thought i saw a set up for sale in the last month or 2, have a scan back thru the for sale section and you might find some.
