Wonder what I can expect performance wise with these fitted?
Throttle body inlet pipe for SE MX-5
SE Intercooler upgrade kit
Goodies getting fitted! :)
- Craig
- Vehicle: Non MX-5
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds! ***
- blackster
Craig wrote:Wonder what I can expect performance wise with these fitted?
Those "goodies" should be considered as items that prevent or reduce performance. IE Loss of power due to heatsoak (OEM IC) & loss of boost (pressure drop or in severe circumstances no boost at all as the rubber TBi has gone woopsies)
The greatest gain will come from changing the air intake and exhaust. There is nothing from stopping you from turning up the boost manually other than boost cut @ 10.5 psi; although you will be sucking and blowing through a straw if you do with the OEM exhaust & air intake.
Be mindful of using a larger IC with the OEM air intake/exhaust as you may experience a small drop in boost.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Fuzzlet
As blackster said, you probably wont notice much of an increase until you do the intake and exhaust. Once you do you'll gain a solid 30rwkw or so. Having said that I'm sure you're gonna enjoy your modified car haha
Congrats Craig, looks like a nice upgrade.
- Craig
- Vehicle: Non MX-5
Bugger, I'm kinda happy not to do the exhaust and intake to be honest!
- Boyracer
- MX-5 Encyclopedia
Just do the exhaust, it's a good upgrade...if you do the intake then you end up needing a ECU and it all gets too complicated.
- Sean
Sell the car, get a 13bt s1 rx7...
Happy I'm back?
Happy I'm back?
Users browsing this forum: No registered users and 210 guests
