When did your coilpack fail?
philz
Wheel guru
Postby philz » Mon Mar 23, 2009 11:21 am
Alright it seems the well known problem of the NB8A is the coilpack.
Just to get a rough idea, oh how widespread the coil pack failures are, please chime in.
And from what I have read, coilpack failure is reduced if you change the leads and plugs every 40K or so...
Car: NA6/8, NB8A/B???
Kms at which is failed:
Did you replace the plugs and leads often, before failure?:
Obviously, all cars are different, giving their circumstances and history. But it's just something of interest.
Postby Okibi » Mon Mar 23, 2009 12:14 pm
Why not setup a pole like they have on the miata.net forum?
wun911
Postby wun911 » Mon Mar 23, 2009 12:16 pm
The NB8B dont have coil pack it has coil over plug, replaced both cam angle sensor and coil over plug at 170,000 km.
every ounce counts
MX5CHIC
Postby MX5CHIC » Mon Mar 23, 2009 12:24 pm
NB8A
My coilpack has not failed
Spark Plugs every 6 months
Leads = never replaced - I clean and test them at least every 6 months.
Only part ever failed was the Fuel Pump
Alex
Postby Alex » Mon Mar 23, 2009 1:44 pm
NB8A
no problems, 50,000km
never changed leads or plugs (still have original ones from factory)
probably change them next service (60,000km) or if i get any misfire problems
Postby Okibi » Mon Mar 23, 2009 3:23 pm
MX5CHIC wrote:..Leads = never replaced - I clean and test them at least every 6 months...
How do you test your leads?
RG.net
Postby RG.net » Mon Mar 23, 2009 5:21 pm
NB8A 150,000kms
Spark Plugs every 5,000kms
Leads, replaced at 125-130k? leads were replaced before purchase though, as they were not stock items.
MX5CHIC
Postby MX5CHIC » Mon Mar 23, 2009 5:24 pm
In the service manual it gives figures relating to the Resistance range for the plug leads, for e.g. 10-12 K-ohms - just grab a good quality multimeter and check that each lead is within the designated range.
irwin83r
Postby irwin83r » Mon Mar 23, 2009 9:00 pm
my nb8a original coil packs lasted over 150,000
bought a new set because of a miss that developed into a huge power cut off above 4000rpm mostly underload. also replaced leads and plugs.. turned out to be a LOOSE cam angle sensor.. same cam angle sensor plug held on firmly with a cable tie is still going strong 160,000ks.. is now being used as a spare (as ive recently put in a lower Ks motor to do a rebuild on the old) and is currently fitted to mxheven's 5 as his cam angle sensor died. (also has my crank angle sensor fitted)
philz
Wheel guru
Postby philz » Fri Mar 27, 2009 11:41 am
Hmmm so from what I can see from the responses, no one has experience coilpack failure?
Except for Okibi, how many kms had your car done?
And it seems that mine has failed, at 84,000km.
NB8A, leads I don't believe had been changed yet, and I would really recommend people who haven't done so, do it, doesn't hurt and will only cost you about $80 for leads + plugs.
ampz
Vehicle: NA6 - Turbo
Postby ampz » Sat Mar 28, 2009 7:55 pm
Just a bit of helpfull advice, Hyundai excel x3 (1996 single and twincam) coil packs are identical in dimensions and performance specs as the NA6.
During the Tagra run Mick commented his were aftermarket Hyundai ones (much cheaper than the Mazda) they are bosch branded too.
Working on an excel today, tool the coilpacks off and compared them to my spare set. Identical. 8)
Huh?
Dave
Postby Dave » Sun Mar 29, 2009 9:54 pm
NB8B 2001 model - front of the two coil-over-plug coil packs failed at 193,000 k's. Cost $250 to purchase the new one with trade discount.
Rgds,
Dave
sledgehammer
Postby sledgehammer » Mon Mar 30, 2009 2:30 pm
NB8B
Must be coincidental but after i turbocharged the car it started missing so first step, i checked and replaced plugs didn't help happened straight away narrowed it down to the front coil while i was at it changed both including leads runs like a dream again 64k only, turbocharged for 2k wierd it happened at such low kays
