DIY radiator hose
mmx005
DIY radiator hose
Postby mmx005 » Thu Mar 19, 2009 6:14 pm
Hi guys, as the topic states, im considering a DIY top radiator hose on my nb8a.
it would consist of some silicone hose bends in 45/90 degrees, some stainless tube and appropriate sized (and quality) hose clamps.
is this a good idea or could the pressure/temp of my cooling system cause issues with my bright spark of ingunity???
cheers guys
Ben
Locutus
DIY radiator hose
Postby Locutus » Thu Mar 19, 2009 7:49 pm
mine's custom with rubber hose & stainless tube. no issues at all, provided you do up the hose clamps properly... :oops:
mmx005
DIY radiator hose
Postby mmx005 » Thu Mar 19, 2009 10:10 pm
i was planning on using T-bolt clamps (at $11 each) meant to handle masive boost, so i think they will be quality enough to do up nice and tight. :D
DIY radiator hose
Postby Okibi » Fri Mar 20, 2009 3:29 am
I don't think the length is enough to warrant the effort and risk, twice as many clamps to leak and don't over tension the clamp and crack the radiator inlet.
I bought some SFS hoses years ago, they were much cheaper than OEM at the time.
Fatty
DIY radiator hose
Postby Fatty » Fri Mar 20, 2009 6:26 pm
yes i'm wondering why you would bother, unless there is some other mods involved such as a coolant reroute that you didn't mention.
mmx005
DIY radiator hose
Postby mmx005 » Fri Mar 20, 2009 8:20 pm
i was told you couldnt get silicone radiator hoses for the nb8a, thats what sparked my idea (and my mania enlarged intake sitting on my top hose).
where would i get these sfs silicone hoses from?? and roughly how much??
Locutus
DIY radiator hose
Postby Locutus » Sat Mar 21, 2009 12:48 am
i also did it because of the mania enlarged intake. my intake was previously rubbing on both the top radiator hose and the underside of bonnet.
not sure where to get silicon hoses from (npower?), but as mentioned be careful of over tightening the clamp at the radiator if you have a plastic (stock) end tank.
DIY radiator hose
Postby Okibi » Sat Mar 21, 2009 2:15 am
mmx005
DIY radiator hose
Postby mmx005 » Sat Mar 21, 2009 7:14 pm
thats the problem im trying to fix Locutus. i think the hot radiator hose is also heating :frown: the air coming into my non boosted engine
Users browsing this forum: No registered users and 21 guests
