It wouldn't be a Exhaust rattle would it?
when i first got my NA6 at 2000rpm it buzzed pretty loudly.. Turned out to be a loose heat shield..
Had it tacked back in place noise gone for good..
Also my alternator bolt was lose creating a rattle at the same rpm.
2000 RPM grind? 1990 1.6 NA
- Dweezle
2000 RPM grind?
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- JBT
2000 RPM grind?
It would be nice to know which model.
NAs had two minor things wrong with them - plug leads and exhaust heat shields. The shields would get loose and make a lovely zinging noise at a certain revs.
- philz
- Wheel guru
2000 RPM grind?
Hmm I'm getting that sound as well, at certain rpm, It's usually more distinct when I'm in 4th but at low revs.
Which exhaust headshields? the one near the cat?
2000 RPM grind?
Mine was the one just before the cat on the downpipe. It just got it tacked on, some guys just put a metal clamp on it.
- JSE
exhaust heat shielding or clutch - if you have an aftermarket heavy duty clutch it may rattle with the 1.6 motors
mine rattles.
i've got lock stewart extractors, stock car & sports exhaust from the cat back.
ever since i installed it i've had the rattle, removed all heat shields & replaced the muffler
after all that i've reduced the noise to 2600-2800 rpm & it generally doesnt do it in 1st gear
i sware its the extractors. its definatelly not hit / rattling on anything. its just their....
so, i wouldnt worry to much. unless you want to go back to a stock system
