Car running weirdly
philz
Wheel guru
Car running weirdly
Postby philz » Tue Mar 10, 2009 4:36 pm
Okay,
I turn on my car, the car starts misfiring, I rev it a bit and it's back to normal, I suspect its the low fuel.
I drive my car out of the drive way to park it outside. turn it off.
About 30mins later, I start it again to go get some fuel.
The car is misfiring, rev it up, nothing happens its all the same.
So anyway I suspect the fuel is low, I crawl to the station.
Full tank of BP 98.
Car still runs like sh*t, I gotta go home.... but now the exhaust is getting louder, and their are smells of exhaust.
The car feels like its stalling, so i need to rev high, max speed is probably 50km/h.
Car splurts to home, I leave it outside my house, turn it off.
Again I go check on the car, turn it on, it works?
I drive it back into the driveway.
So wtf just happened, and now I believe I killed my cat, because it's smelling bad of fumes.
I don't believe the fuel pump has been replaced.
wun911
Car running weirdly
Postby wun911 » Tue Mar 10, 2009 4:43 pm
Sorry but is this the same car that had the new cam angle sensor and new coil over plug assembly?
every ounce counts
philz
Wheel guru
Car running weirdly
Postby philz » Tue Mar 10, 2009 4:45 pm
nope, haven't had a problem with this car yet.
First mechanical problem.
Other notes:
Car is 1999 NB8A, manual, 78000km.
And also the car is doing it again, turn it on, works good about 10secs later... misfiring and smelling.
I just did it AGAIN, the car misfires, then about 3secs later works fine, about 15-20secs later it start to misfire.
JBT
Car running weirdly
Postby JBT » Tue Mar 10, 2009 5:00 pm
Plugs and leads?
philz
Wheel guru
Car running weirdly
Postby philz » Tue Mar 10, 2009 7:43 pm
Thanks,
I'm guessing its plugs and leads as well, because I bought the car at 76,000km, but I'm not exactly sure when they were replaced.
Could their be any other problem?
Craig
Car running weirdly
Postby Craig » Tue Mar 10, 2009 7:48 pm
Didn't the 99-2000 have ignitor issues? :?
JBT
Car running weirdly
Postby JBT » Tue Mar 10, 2009 7:49 pm
There could, but that sounds like your problem and it's the cheapest fix. If it isn't the problem, you'll have a known good spare set. Try it first and let us all know how it went.
Russellb
RIP Nov 2014
Car running weirdly
Postby Russellb » Tue Mar 10, 2009 8:30 pm
philz wrote:nope, haven't had a problem with this car yet.
Other notes:
Next time it does it try pouring a small amount of water over the coil packs
If it runs fine then you need new coils
My ClubmanRebuild
MX5 SE Rally car is HERE :)
philz
Wheel guru
Car running weirdly
Postby philz » Wed Mar 11, 2009 12:41 am
Thanks guys.
But what leads and spark plugs are good, or anything decently priced that does the job?
JBT
Car running weirdly
Postby JBT » Wed Mar 11, 2009 7:40 am
NGK spark plugs - BKR5E-11 Website.
Plug leads - Genuine Mazda or Repco/Autobarn/Supercheap/etc.
philz
Wheel guru
Car running weirdly
Postby philz » Wed Mar 11, 2009 10:22 am
Cheers JBT.
I just thought that there may be a difference with say thicker Magnecore or Standard Mazda items.
Also an update:
I have not done anything since yesterday, when it would idle normally, then suddenly misfire, then work again.
Woke up this morning, got in the car, turned it on, and it WORKS fine?
No misfiring, car is running perfectly, and there doesn't seem to be any smell?
SO I'm just waiting for it to misfire again, but it's not, I take it around the block a few times, it's running stronger than ever with the new fuel.
So WTF?
The only cool thing that came from this, was that it made one of the ends of my exhaust a nice burnt purple colour, which must have happened yesterday when it was misfiring badly.
Car running weirdly
Postby bruce » Wed Mar 11, 2009 10:32 am
Leads.
wun911
Car running weirdly
Postby wun911 » Wed Mar 11, 2009 10:32 am
fuel filter and dirty batch of fuel?
every ounce counts
philz
Wheel guru
Car running weirdly
Postby philz » Wed Mar 11, 2009 10:53 am
bruce wrote:Leads.
Can leads be a temporary on and off thing?
I thought they were, if it either works or it doesn't work.
wun911 wrote:fuel filter and dirty batch of fuel?
I'm thinking it could be the fuel as well, because I have only been pouring half for the last couple of months, and the fuel in the car was about a month old, and I have also heard about long periods of time, with half empty tanks can cause condensation?
Car running weirdly
Postby sliq » Wed Mar 11, 2009 11:00 am
check out www.miata.net
they might have a few fixes on there.
