na6
silvermx5 project supercharged
awsome find dude!
looking forward to seeing updates!
- orx626
- Vehicle: NC - Rotary
silvermx5 wrote:it has a blue mazdaspeed comp plate on the fire wall stating B spec would that relate to the amount of boost ? i havnt had a chance to measure the pulleys as yet
If the supercharger and crank pulley's are sized for the supercharger to reach its maximum rated rpm then the maximum boost you will see is around 6 psi. If it still has the standard pulley's then you will see a tad over 4 psi.
- PUR157
B spec AFAIK is just the name they gave to the Mazdaspeed Supercharger package
Great find there...
Oneness of Man and Machine
See the little black hose coming off the inlet to the charger and arching up and over the cast allow outlet? Where does it go from there? Please post a pic.
M
M
Congrats, looks like a nice project.
- Jeo
Looks like one hell of a find. Well done!
thought i read something recently about this front cut - sounds like it will be a great project - really look forward to hearing about it.
silvermx5, i think M means the thin black one just above the Jackson Racing logo cast into the charger outlet manifold cover. from memory it's the idle balance line & it goes to the fitting on the JRSC airfilter assembly.
