Supercharger Bracket mounting points
white1.8
Postby white1.8 » Tue Feb 24, 2009 12:27 pm
Hello,
I have recently started trying to attach a SC14 (the bigger version of the SC12) supercharger to the side of my NA8 engine (hot side) and was wondering where any of the professional kits or anyone who has done this mounted the brackets, if anyone could point me in the directions of some professional instructions that would also be very helpful.
Currently I'm thinking about removing the power steering but keeping the AC, has any one kept both and still fitting the supercharger under the bonnet?
Thankyou for any assistance
Postby Okibi » Tue Feb 24, 2009 12:29 pm
Do a search, I had a photo of one fitted to an MX-5 race car. I don't think there's a "kit".
Mokesta
Postby Mokesta » Tue Feb 24, 2009 1:50 pm
I don't know about the mounts on the SC14 or the size of the unit but you may be able to copy the mounting technique used in the JR Eaton M45 kit. I know where there is a standard JR tensioner for power steer and AC cars, unused in Brisbane. Maybe you can make it work.
It is really only the large nose pulley on the SC14 with the clutch in it that I can see being a problem.
Where in Bris are you?
M
Postby Okibi » Tue Feb 24, 2009 7:14 pm
Roger Trethewey has an SC13 mounted down there on his track car.
white1.8
Postby white1.8 » Tue Feb 24, 2009 9:25 pm
thanks for the input so far, im interested where on the engine the supercharger mounts actually attach to so a picture from the other side would be much more helpfull,
as for the professional install instructions i was meaning any of the professional kit install instructions so i can see where they mounted the supercharger to on the engine
Cheers for the help so far
Mokesta
Postby Mokesta » Wed Feb 25, 2009 12:19 am
Look at this thread:
viewtopic.php?f=57&t=29490&st=0&sk=t&sd=a&start=60
The plated bracket that spans two head studs and the engine lifting lug is the supercharger bracket. Follow the thread and see how the SC attaches.
M
Postby 93_Clubman » Wed Feb 25, 2009 1:11 am
white1.8 wrote:if anyone could point me in the directions of some professional instructions that would also be very helpful.
as for the professional install instructions i was meaning any of the professional kit install instructions so i can see where they mounted the supercharger to on the engine.
The following might also help - more comprehensive than their old instructions:
JR SC install instructions revised Jan 07:
http://www.miatamania.com/graphics/prod ... 99-170.pdf
white1.8
Postby white1.8 » Wed Feb 25, 2009 1:46 pm
Thanks everyone so much for the help,
Sorry I didn’t answer in my last post I'm located on the north side of Brisbane in Wavell Heights (near Chermside).
Ill have a look though those links, hopefully that will sort everything.
Users browsing this forum: Bing [Bot] and 227 guests
