SE infamous TB inflation
blackster
Postby blackster » Sat Feb 21, 2009 8:40 pm
http://www.youtube.com/watch?v=3M14neZZMY4
T-bolt clamp fitted to the OEM TB inlet, what will happen with the OEM screw clamp. :oops:
Previous
04' MX5 SE.
02' MX5 Classic ed.
Craig
Postby Craig » Mon Feb 23, 2009 12:21 pm
Blackster,
I had mine pop off some months ago, but just refitted it and then tightened the crap out of it and all's well.
Mind you awfully tempted to fit the metal mod pipe! :wink:
Craig
Postby bruce » Mon Feb 23, 2009 12:53 pm
Does the pipe balloon under normal boost?
Craig
Postby Craig » Mon Feb 23, 2009 12:54 pm
Sure does! :shock:
MINX
Postby MINX » Mon Feb 23, 2009 1:01 pm
So who is organizing the group buy, and where from?
Postby bruce » Mon Feb 23, 2009 1:07 pm
I'm guessing if you ditch it for solid pipes all around it would improve throttle response?
Postby Okibi » Mon Feb 23, 2009 2:31 pm
But that rubber is calibrated specially by Mazda engineers to absorb boost spikes, it's much smarter than pop off valves that waste precious boost. :mrgreen:
Postby Jeo » Mon Feb 23, 2009 4:48 pm
Damn!
blackster
Postby blackster » Mon Feb 23, 2009 4:49 pm
I have already replaced mine a while back, you guys could enquire directly to flyin miata about a group buy.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Fuzzlet
Postby Fuzzlet » Mon Feb 23, 2009 11:44 pm
Interestingly, since changing to the FM metal pipe, car seems to accellerate a little bit harder...plus runs more boost :wink:
Postby bruce » Tue Feb 24, 2009 11:23 am
Throttle response should increase due to all the compressed air actually getting to the TB quicker (not lingering about in the piping).
Smacca
Postby Smacca » Tue Feb 24, 2009 11:07 pm
I had the Flyin Miata metal intake pipe along with a GFB BOV fitted to my SE only just last week. Throttle response is sharper and acceleration is also improved. There is a noticeable kick right at 5,000rpm. :D
MINX
Postby MINX » Fri Feb 27, 2009 11:38 pm
Fitted Mania/FM SS Throttle body today.
Will have to play with BOV pressure and MBC.
Boost increased and much sharper throttle on/off response.
Finding a 35mm-20 reducer was a bugger.
"edit" Reroted pipes - thanks Blackster.
Have serious boost cut happening now. But hell it goes well.
Fuzzlet
Postby Fuzzlet » Sat Feb 28, 2009 4:14 pm
How did u re-route the pipes? (and as such hitting boost cut) I'm running same intake, with wastegate pressure take off coming from the manifold (instead of inlet pipe as per factory) but having no issues with boost cut
MINX
Postby MINX » Sat Feb 28, 2009 4:36 pm
Fixed now.
I didnt have the routing quite right.
Now its ok, but i had(over the past few weeks) gradually ramped up the BOV pressure and MBC too hard.
I reset the BOV soft, and adjusted the MBC back so now boost is hovering around 10 and throttle control isnt as touchy/harsh as it was. The BOV wasnt letting go fast enough on backoff at high rpm.
Seems to be showing higher boost in 1st and 2nd than it used to.
