Gauges
corners
Vehicle: ND - Supercharged
Gauges
Postby corners » Sun Feb 15, 2009 3:21 pm
Hi All
I am thinking of getting some more gauges. What are the typical applications most people use?
I have an Oil Pressure gauge ready to be installed and was thinking of adding Oil Temp and maybe water temp.
These are the options I was looking at:
Oil Temp 100 - 250deg. F
http://autometer.com/cat_gaugedetail.as ... 101&sid=11
Oil Temp 60 - 150deg. C
http://autometer.com/cat_gaugedetail.as ... 468&sid=11
Water Temp 100 - 250deg. F
http://autometer.com/cat_gaugedetail.as ... 113&sid=11
Water Temp 40 - 120deg. C
Is it better to work in deg. C or deg. F?
Jaron
Gauges
Postby Jeo » Sun Feb 15, 2009 4:10 pm
Sorry if this sounds like a stupid question, but why would you want to work in fahrenheit?
corners
Gauges
Postby corners » Sun Feb 15, 2009 4:40 pm
I probably dont but just posted to see what other people use and work with.
mx52nv
Purple Porsche Eater
Gauges
Postby mx52nv » Sun Feb 15, 2009 4:50 pm
I have boost pressure, oil temp, water temp, and exhaust temp in my NA6 turbo. :mrgreen:
Fuzzlet
Gauges
Postby Fuzzlet » Mon Feb 16, 2009 1:52 pm
I have (but not yet fitted) Boost, Water temp and Oil temp for the SE. I went for celcius for the guages, since thats the standard temp measurement in Australia and what I've gotten used to
corners
Gauges
Postby corners » Mon Feb 16, 2009 2:01 pm
Fuzzlet wrote:I have (but not yet fitted) Boost, Water temp and Oil temp for the SE. I went for celcius for the guages, since thats the standard temp measurement in Australia and what I've gotten used to
Thanks!!
Also where do you typicall have the sender for the oil temp?
Fuzzlet
Gauges
Postby Fuzzlet » Mon Feb 16, 2009 2:55 pm
For the oil temp sender I'm going to use a sandwich plate between the filter and block (or in my case, filter relocation piece and block). Was $30 from justjap (plus postage if you cant pick it up) - clicky
green_comet
Car Detailing Guru
Gauges
Postby green_comet » Mon Feb 16, 2009 3:36 pm
You dont have to goto that much trouble...
I use one of these, for my VDO oil temp gauge.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO-323055&N=700+0&autoview=sku
It replaces the sump plug, and sends the oil temp using the small clip on the end. You just need to run a wire from the sender to the gauge inside. I have been using one in my car for about 3 years with no problems...
corners
Gauges
Postby corners » Mon Feb 16, 2009 3:50 pm
Would that work with the Autometer gauges though??
bensale
Gauges
Postby bensale » Mon Feb 16, 2009 4:02 pm
green_comet wrote:I use one of these, for my VDO oil temp gauge.
Thats awesome! I think I may get one of them.
www.othersideproductions.com
Benny
Gauges
Postby Benny » Mon Feb 16, 2009 4:05 pm
I've got a boost gauge, and it reads in lbs per sq inch, because reading in bars is just too difficult to understand, even though I know htat about 15.1 lbs + 1 bar.
How many of you read your tyre pressures in bars, rather than lbs?
Gauges
Postby Mr Morlock » Mon Feb 16, 2009 5:49 pm
I think Aust was very smart all those years ago to go metric. Anyone who had the misfortune to have struggled with the nonsense of a daft imperial system which even varies with US imperial would thank our administrators. The simplicity of metric is a huge plus and a saver of time and it is has a logic. Personally I do not ascribe to remnants of imperial still hanging about as it strikes me as a reluctance to move forward. We are a long way in front of some other countries who seem to hold on to these antiquated measurements as some sort of badge of honour. Once you read measurements in metric they take on their own meaning and it is not really necessary to equate it to a system which is by and large dead in this country.
RG.net
Gauges
Postby RG.net » Wed Feb 18, 2009 7:48 am
i have the following installed:
air/fuel
water temp
volts
oil pressure
on the list are:
vaccum (for the quads)
oil temp
Gauges
Postby Okibi » Tue Feb 24, 2009 1:32 am
Something with peak hold would be nice.
For 3 gauges in a single din slot probably Coolant temp, Oil Temp, Oil Pressure.
Fabio
Gauges
Postby Fabio » Tue Feb 24, 2009 11:09 pm
I say get the gauges in what ever measurements you fell comfortable in using. I grow up with the metric system in school, but when I started working, I had to use the imperial system for alot of the things I worked with. When I think about boost pressure, I think in psi, but when I think of hydraulic system pressure, I think in bar.
P.S. Benny, 1 bar is 14.7 psi :wink:
