These Stage 8 locking nuts are a brilliant design. Tighten up the nut as usual, then slip the locking tab over top and use the C-clip to hold it. Voila, a nut that cannot possibly loosen. If you need to remove it, pop the clip off and remove the tab. Simple and effective. We recommend this hardware on the turbo-to-manifold studs for any Miata that sees track use. Available as an option on our turbo kits.
http://www.flyinmiata.com/index.php?dep ... r=36-00000
