How to bring extra set of rims for Track day
and one in the boot
- PUR157
Don't forget something to tie down the bootlid!
I know from experience that I can't get it to shut...
Oneness of Man and Machine
- mxrx
Hi All
I trailered a road registered MX-5 down to the last Wakefield Track day. Mainly because I have a trailer and tow vehicle and the driver, Lyndsay Burke and I we able to travel down together, The reason we trailered the car was that it has done over 230,000kms and so driving it down was going to put more wear on the engine and Lyndsay wanted every edge he could. He also had another set of tyres for it as well as tools, jack etc to carry.
So if you can, it is always a good idead to trailer your car to a track day.
- AB7
Hi guys, I'm wondering how many k's would a set of semi slick last? People often mention them in term of track days, how many k's on average?
- Jimmy
I got some looks coming back from Wakefield looking like this:
- CheyneX5
someone looks happy
90' NA6 - Classic Red
- Jimmy
just a quick follow up to this , while i'm thinking of it. i've just got a new set of 205 r888's. my previous rubber was 195. the 205's don't want to squeeze into the boot - too fat. so the "3 in the cabin, 1 in the boot" trick seems to only work with smaller tyres.... or maybe i'm just not using enough force to squeeze it in there.
- bensale
I would say you aren't using enough force. I've fitted a 205/45/16 in my boot & I also haven't removed the carpet. Although what is the sidewall ratio of your tyre?
www.othersideproductions.com
- bensale
Going by the miata.net tyre size calcuator the diametre is about 9mm smaller than the 16' wheel I've fitted in the boot so that isn't the problem. It's only 4mm bigger than the stock tyre too.
I'm surprised it doesn't fit, perhaps anouther try, I found I really had to squeeze it in and apply a fair bit of force to get it to sit low enough to shut the boot.
- greenMachine
Try wriggling, it needs to go in at the right angle. I know I got a 205/50x15 in the boot of my NB. It took a bit of manoevering, and was a pretty snug fit when in, but it certainly can be done.
Also pays to remember that not all 205's are the same width.
It is surprising the variance in width between tyres that are supposed to be the same.
thank guys i'll try and wiggle it a bit next time. but yeah, for a 205 it does seem rather wide jake ... not that i'm complaining about the extra girth at all.
Wriggle it, and make sure that it's at the right angle.
But a little bit of KY jelly will get you a LONG way!
Or have I lost the thread..................?
\"Never squat whilst wearing spurs\"
Users browsing this forum: No registered users and 429 guests
