DIY AC removal from the prince of liteness...
wun911
Postby wun911 » Wed Jan 28, 2009 9:25 pm
I removed my AC to save weight, and improve cooling.
Things you will need:
1 PS only belt (I got a DAYCO P4K 0853 from MX5 parts UK)
Degass the AC in a shop before you begin
Sockets 8 10 12 14 mm and various small extensions, and a philips head screw driver.
Time it will take to take it out and put every thing back in aprox 3 hrs
Begin by removing the radiator, its very simple undo the top and bottom radiator hose and detach both fans. Unbolt the radiator from the car and lift it out of the way.
You will now have access to remove the condensor that kinda restricts air flow to your radiator. From memory you will need either a 10 or a 12mm socket and a philips head screw driver to remove the pipes leading to this condensor. One of the pipes leads to the AC compressor and the other leads to a bottle near the firewall. Remove them both to get them out of the way. NB pease be carefull if you would like to re install your AC because the pipes are thin aluminum and easily bent.
There is a wire that connects the car to the AC remove it.
To gain access to the AC pump remove the air filter box 3 bolts 12mm and 10 mm.
Basically there are 4 x 12 mm bolts that hold the AC pump to the car's engin. You will need to remove all of them they are not seized on but they are difficult to get off due to the tight space you may want to use some extensions etc.
In this pic you can see the socket is on one of the 12 mm bolts right next to the radiator hose going into the engin. (I opted to remove the radiator hose so I could swing the socket you have removed rad anyway so no coolant loss either way)
I cant show a photo of the other three bolts they are out of sight so to gain a better understanding in this pic you can see the AC compressor and the four bolts sticking out of it those are the 12mm bolts.
Once the four bolts the the AC compressor have been removed it will fall on to the plastic engin under tray. Its difficult to remove from the top of the car because the sway bar is in the way, rather than removing the sway bar you can crawl under the car and undo the little hatch that gives you access to the bottom radiator hose (8mm socket). From there it conviently falls right out of the car
AC is now removed, so its time to put the smaller PS only belt back onto the car.
Losen the two 14 mm bolts the black arrows are on.
The begin the unscrew the 12 mm bolt the red arrow is on. This will give you enough slack to put on the smaller PS only belt.
Begin to tighten the red arrow and when the belt is firmly in place tighten the two 14mm bolts.
When finished without the AC should look like this.
Im going to weigh everything up and record the total weight lost soon.
every ounce counts
CheyneX5
Postby CheyneX5 » Wed Jan 28, 2009 9:28 pm
your going to hate driving to winton.... 40 degrees :oops:
90' NA6 - Classic Red
bensale
Postby bensale » Wed Jan 28, 2009 9:30 pm
:roll: :roll: :roll: :roll:
www.othersideproductions.com
wun911
Postby wun911 » Wed Jan 28, 2009 9:32 pm
Yeah been to a few 35-38 deg track days...
Ironic I removed the AC on a 40 deg day and it didnt bother me a bit...
I never use the AC its zaps power from the car, I would rather have roof down, when the AC was working it was like beeing coughed on by a mouse.
every ounce counts
bensale
Postby bensale » Wed Jan 28, 2009 9:38 pm
I must admit I rarely run my A/C either, just 5 mins a week to keep it working. Still, I wouldn't even remotly think about removing it.
Juffa
Postby Juffa » Wed Jan 28, 2009 9:56 pm
Funny, I didn't see anything about protecting the environment from the Air Cond gas by having it removed at a air cond workshop?
By the way well done on sticking to your weight loss goals.
J
Blue94t
Postby Blue94t » Wed Jan 28, 2009 10:19 pm
Juffa,
He caught the gas in a garbage bag
that way he can either reuse it if the AC goes back on or he can sell it on eBay.
As for all you AC using wusses, go drink a cup of concrete :lol:
CheyneX5
Postby CheyneX5 » Wed Jan 28, 2009 10:27 pm
With pleasure :twisted:
Locutus
Postby Locutus » Wed Jan 28, 2009 11:05 pm
next step P/S removal? more power & more lightness... :P
wun911
Postby wun911 » Wed Jan 28, 2009 11:23 pm
I'm not sure about PS I think it will stay.
Out of curiosity is it a straight fwd removal or do I have to buy extra bits?
When I become anorexic how will I cope when I have to change direction quickly on the track?
I'm very reluctant to put on more mussle mass would rather do palaties than weights...
every ounce counts
Postby 93_Clubman » Wed Jan 28, 2009 11:40 pm
wun911 wrote:I'm not sure about PS I think it will stay.
I think you need to replace the PS rack with a manual steering rack.
PASHN8
Postby PASHN8 » Thu Jan 29, 2009 12:21 am
You are a sick man Wun, sick man indeed *shakes head* lol!
P.S. I will run you with my AC turned on full blast and still kick your arse! :P
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Stu
Postby Stu » Thu Jan 29, 2009 12:31 am
wun911 wrote:Ironic I removed the AC on a 40 deg day and it didnt bother me a bit...
It will one day, most likely in the very near future. :mrgreen: :mrgreen: :mrgreen:
wun911
Postby wun911 » Thu Jan 29, 2009 2:38 am
Out of curiosity how do you guys check if the belt is too tight or too lose?
Is there are torque wrench thing for a belt? Or does x amout of torque on the adjuster = the correct tension??
every ounce counts
Boags
Postby Boags » Thu Jan 29, 2009 9:22 am
I took my mouse to the vet. Now when he coughs it is quite cold. :mrgreen:
Love the liteness; would never do it myself. (I installed aircon on my NA6 just before the turbo... Priorities... :oops: )
