OMX-596 - 1996 Spec'd NA6 - Updated 21 Apr 2013
CapitalF
Vehicle: NA6 - Turbo
OMX-596 - 1996 Spec'd NA6 - Updated 24 Jan 2009
Postby CapitalF » Sun Jan 25, 2009 10:22 am
Danny - it's lookin great! I'm green with envy of all that power.
Can certainly empathise re working yesterday - I installed the new clutch and lightened flywheel. A real bugger of a job when you are doing it on short stands, wearing glasses & sweating like a pig, in a small shed!
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Postby Okibi » Sun Jan 25, 2009 2:00 pm
graemebc wrote:Did he not say he was fitting an ARE radiator as well Okibi?
Yes you are correct very observant, MX-5 mods are like pr0n to me, I like the pretty pictures :mrgreen:
Postby Hammer » Sun Jan 25, 2009 2:07 pm
Looks like it's coming along nicely.
Fatty
Postby Fatty » Sun Jan 25, 2009 2:11 pm
yes but that doesn't actually address your initial comment about the intercooler.
danny is there going to be a ARE water to air intercooler fitted, to replace that standard cross pipe?
it's looking really nice so far 8)
Postby 93_Clubman » Sun Jan 25, 2009 2:13 pm
Fantastic Danny - can't wait to read & see more about the install & development - I think the M45 is underestimated, although admittedly it requires going the extra mile & has a lower potential ceiling than the MP62.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Jan 25, 2009 10:17 pm
I am pretty sure danny designed/co designed the pwr water to air intercoolers. I would think he would be doing his own version specific to this car.
Postby orx626 » Sun Jan 25, 2009 10:43 pm
16bit wrote:I am pretty sure danny designed/co designed the pwr water to air intercoolers. I would think he would be doing his own version specific to this car.
PWR's opposition actually James :lol: ... I've done a fair bit of R & D for Aluminium Radiators and Engineering (ARE) at Brendale in Brisbane... hence you see a lot of their handy work on my vehicles...especially the 626. I'll talk more about the IC plans for this car a bit further down the track. The main focus at the moment is to get it up and running so I can make it to the first club track day of the year in early March.
16bit
Postby 16bit » Sun Jan 25, 2009 10:53 pm
damn i was close though
Postby orx626 » Sun Jan 25, 2009 11:17 pm
Well today was as stinkin' hot as yesterday :x :x :x . However great progress was made but not as much as I would have liked!
The day began with the fitment of the replacement aluminium radiator from Aluminium Radiators and Engineering. The unit is almost dimensionally the same as the standard item so it uses the standard side brackets and fans. It is a nice bit of kit.
To help reduce the amount of air bypassing the core I added adhesive backed foam (Neoprene) to seal around the fans, and between the radiator and the radiator support panel.
Here are the standard fans bolted onto the radiator....
....and installed in the car. It's nice everything just bolts straight up :D .
The next mini project for the day was to design and manufacture a heat shield to go between the supercharger and the extractors. It uses an aluminium strong back covered in aluminised fibreglass sheet that is attached by oversized rivets. It leaves a nice air-gap between the supercharger and the heat shield. Here is the result....
Thanks to Saboteur and zoomzoom for the heads up to use the throttle cable from the G-series Bravo ute. 8) With some minor tweaks the cable was absolutely perfect...the standard brackets made the routing of the throttle cable look very factory. :D
A tweak here....
....and a tweek there.
Soooo this is where I got to when I'd had enough.... mechanically the s'charger install is complete. I even ran it in the standard ECU to make sure the TPS extension was right and to bleed the cooling system. I think it looks great! :mrgreen:
The plan for tomorrow is to get the MS PNP and the LM-1 installed so that I can drive it home and re-direct my focus back to the NC. I'll do something with the windscreen washer bottle later.....
AJ
OMX-596 - 1996 Spec'd NA6 - Updated 25 Jan 2009
Postby AJ » Sun Jan 25, 2009 11:21 pm
you don't believe in one thing at a time do ya Danny?? :lol:
nice bit of kit you jammed in that engine bay :mrgreen:
XMX5 Rogues
Postby orx626 » Sun Jan 25, 2009 11:36 pm
It's been a long time coming AJ :P I've had the supercharger kit since June 2007 and the MS PNP since June 2008. :shock: :shock:
Enough was enough!!! :lol:
....and having a second kid due in June doesn't leave me much time to knock a few projects over :P :lol: :mrgreen:
AJ
Postby AJ » Sun Jan 25, 2009 11:51 pm
sounds like you should stop knocking things over to me :P :lol: .................need anyone to take the cars for a blat while ya busy in June???.............be a real nice birthday pressie for me :mrgreen: ...........I was born in June as well............one or two years back :|
XMX5 Rogues
Postby 93_Clubman » Mon Jan 26, 2009 4:12 pm
Looks just great - can't wait to read the write-up following today's efforts - many thanks also for the throttle cable tip.
Postby orx626 » Mon Jan 26, 2009 10:46 pm
Well I'm ready for the weekend now!!! :P .....just have to wait another 4 days. :lol:
Didn't quite achieve everthing that I wanted to today...should be getting use to that by now! :lol:
The main focus of the day was to get the MS PNP installed and working well enough to drive it home.
Here's a sequence of photos of accessing the std ECU.
Thanks to Mokesta for knocking up an extra bracket so that I could utilise the standard ECU mounting brackets.
The MS PNP in position :mrgreen: .
The extra bit of wiring I needed to do to complete the MS install was to connect the Intake Air Temp sensor (mounted in the dummy throttle body) to the ECU.
Thanks to zoomzoom for taking me through the basics...it certainly saved me a lot of time. 8) As you can see from the below piccie the car got me home with enough time to give the new turf its first hair cut :P . With the timing adjusted correctly it now goes extremely well but is noticebly rich. Next weekend's job is to install the wideband (Innovate LC-1) so that real-time fuel map adjustments can be made. It really feels like an engine of a larger displacement now resides under the bonnet :twisted: . It's just what I was hoping for. 8)
Saffa
Vehicle: NA6 - Supercharged
Postby Saffa » Tue Jan 27, 2009 9:25 pm
Looks good Danny, some nice pics up there.
That radiator looks damn hot!!
FOR SALE>>93 NA6 FFS MP62 - NA8 Brakes, 4.3 LSD Torsen II.
http://mx5cartalk.com/forum/viewtopic.php?f=73&t=54518
