MX5 Factory CAI setup (with pics) 56k warning
crzymx
Postby crzymx » Fri Jan 23, 2009 8:07 pm
I will begin by explaining how frustrated i am that my previous post which took me 30 mins to writeup was lost at the expense of an accidental click of a link. Thankyou internet explorer 7!
Now i will continue to re write my expiriences with installing the MX5 Factory CAI.
NOTE: Information is based on fact and bias. Which parts are fact and which parts are biased is anyones interpretation (the beauty of bias!)
I first began with the drilling of the firewall. Unfortunately i couldnt find a 76mm holesaw so a regular drill had to do. 346 holes later i was able to punch oput the hole with a hammer and flathead. I continued to grind back the are with a dremel however i later upgraded to a bigger grinding attachment on the drill as the dremel is probably more apporopriate for toenails! After smoothing to hole i attempted to try and fit a 76mm heat tube in a not so 76mm hole. I soon gave up and found a perfect piece of PVC tubing that i could wedge into the hole and use a hose clamp to secure the tube to that. Next i lifted the cowling behind the firewall up and used a stanley knife to cut out a groove so that it would sit flush. This brought me to my next trouble.. trying to get the screw back into the cowling on the right hand side, something which proved to be very hard as there was a 2cm space to use when screwing. I guess you could say i gave up, im sure its not going anywhere. Heres the end result.
Next it was time to fit the filter... I started by spending 15 mins trying to ge the bloody stock airbox off, and was left with many existing holes from which to choose my bracket positioning from. My first dodgy attempt involed a horizontally placed steel bracket which was bent at the tip to accomodate the positining of the bolt from the filter brace. This was soon replaced with a vertical bracket bent to fit, this was the best option, and very effective, however it wasnt enough. The AFM was still heavy and i found it sagged so i found the only piece of metal i could find which looked like it belonged to a structural part of a house 20 years ago!. After a lot of trial and error, i managed to fit it and it was effective in supporting the AFM (try and guess which one was supplied with the kit and which was not :P). Obviously everything was hose clamped together, then a hole was cut into the silicon adapter with a stanley knife to allow the fittment of the air sensor. The next step, which was also the hardest involved relocating the crucial MX5 Factory sticker. No offence to dick but the shiney aliminium enclosure wasnt the ideal place to put it. So i stuck it at the front of the engine bay.
After being fed up of not being able to use the window washing function as the washer bottle was being thrown around in wierd positions, i finally proceded to the garage and set out upon bracketing it steady. Using a picture of a random MX5 Mania CAI install i found, i came up with the idea to use anothe REALLY thick piece of metal to bracket it in. It is just a straight piece of metal which bolts onto an existin hole which sits on an angled face of the strut tower assembly, straight onto the washer bottle. Utilising bolts taken out with the stock airbox, hows that for smart ;)..
This is the finished product..
Whoops i mean this is the finished product :mrgreen:
And yes i know my engine bay is dirty but what can i do, i really cant get around to cleaning it, maybe in 6 years time when its time to sell.
In conclusion, i think the MX5 Factory intake, based on logic has an advantage over the mania type in terms or filtering as it utilises a significantly bigger filter, and spun aliminium enclosure as apposed to a bodgy plastic one. Also the filter cone has a vortex feature in which it has a moulded type which in fact creates a vortex for beter induction (open for debate). Now with the tubing, im not a big fan as i would prefer not just something more heat resistant as it is a heat resistant tube, but something that is a straight pipe with no flex, and a smoother inside for better flow of air. So yes mania youve got points on that one. And in terms of asthetics, yes mania wins, however the mx5 factory type would provail if only it was a one piece setup because the filter and enclosure is absolute sex as it is, its just let down but the bendy straw of a tube.
Hope this helps, informs, entertains. Im going to try and update with some running videos for sound, and maybe dyno readings in the future. Thanks guys!!
crzymx.
P.S I have not proof read purely because i cant be bothered. Im forwarning you mx52nv..
DIY is the new black!
CheyneX5
Postby CheyneX5 » Fri Jan 23, 2009 8:14 pm
Nice write up...
MANIA CAI FTW!!!
90' NA6 - Classic Red
Mr_Q
Postby Mr_Q » Fri Jan 23, 2009 8:38 pm
CheyneX5 wrote:MANIA CAI FTW!!!
Yup ...
It is a good write up though. :)
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
philz
Wheel guru
Postby philz » Fri Jan 23, 2009 8:43 pm
wow, to be perfectly honest, it looks like crap.
Very ghetto style; the tubing, and not to mention the pod filter.. what is with the clips... [ I know it's to open and change/clean the filter] but ... *vomit*
Mania style prevails here.
Or even K&n apollo
crzymx
Postby crzymx » Fri Jan 23, 2009 9:10 pm
Well if your into chrome finish plastic, and poxy quality c.f, then yes it does look like crap.
No need to be so blunt.
mx52nv
Purple Porsche Eater
Postby mx52nv » Fri Jan 23, 2009 9:11 pm
Okay...fixed! :mrgreen:
Good post on this CAI btw :wink:
crzymx
Postby crzymx » Fri Jan 23, 2009 9:20 pm
Haha thanks, i knew you would get to it.
CheyneX5
Postby CheyneX5 » Fri Jan 23, 2009 9:29 pm
crzymx wrote:Well if your into chrome finish plastic, and poxy quality c.f, then yes it does look like crap.
Plastic will do a very similar job, it's also lighter... i'm sure Wun will agree that the metal casing and all those clips will be alot heavier than mania's design.
To be honest, even if mx5 factory's intake is better, it would only be by roughly 1/2 a kW.
Also, are you considering playing around with materials re: piping? you should try getting a pipe like mania use and see if it's better than the hosing, will change the noise too (a bit) and if you dont like it, change back to the hose.
Also these intakes are good but there are bigger, better things out there. As soon as i can afford an ECU where i dont need my AFM anymore, i will be getting rid of the mania CAI for a short ram coldside CAI.
I am interested to see how it goes though mate, might pop over next week and take a look :)
I'm sure it purrs nicely.
grump
Postby grump » Fri Jan 23, 2009 9:30 pm
Was this cheaper or dearer than the Mania one. please don't say dearer.
CheyneX5
Postby CheyneX5 » Fri Jan 23, 2009 9:35 pm
it's a touch under double what the mania one is worth, good system but too much $$$. and for how similar they are... no way is it worth it.
crzymx
Postby crzymx » Fri Jan 23, 2009 9:36 pm
A lot dearer. 250 dollars dearer including gst. I know its ridiculous, but thats what he charges, i guess you pay a price for establishment.
Uhm yeah i would like to experiment with a different hose, i might see if i can pinch some stuff from bunnings, because although dick is adament that the bendy hose is backed by rally drivers etc etc, i really prefer the one piece concept, ya dig..
Yeah i wanna compare mine and yours cheyne, would be a nice comparison at he dyno day, im gonna get the day off, wbu?
crzymx
Postby crzymx » Fri Jan 23, 2009 9:37 pm
CheyneX5 wrote:it's a touch under double what the mania one is worth, good system but too much $$$. and for how similar they are... no way is it worth it.
Yeah its worth it, manias quoting a 'couple of months wait" on the system as they have none in stock, yeah right, in those months ill make that difference up without realising.
CheyneX5
Postby CheyneX5 » Fri Jan 23, 2009 9:40 pm
when i get the car back mate i will come over, we can just take out my mania CAI and put it in your car, im thinking about running the car on the stock airbox for a while, want to see what it's like, how different it is etc etc etc
SuperMazdaKart
Postby SuperMazdaKart » Fri Jan 23, 2009 10:02 pm
DIY beats both of them :D
Mine costed about $120 all up I think.
I eventually took off the lower clamp on the joiner so it could be pushed further onto the filter casing for a more secure fit.
I actually bought another shielded pod filter yesterday for the GTR. A slimmer more bling JetCo version yet pretty similar internally to the Simota shielded pod (probably same manufacturer). Unfortunately not much room at all for ducting.
Last edited by SuperMazdaKart on Fri Jan 23, 2009 10:08 pm, edited 1 time in total.
crzymx
Postby crzymx » Fri Jan 23, 2009 10:06 pm
That acutally nice, just not a big fand of bendy straw plastic tubing, and the way its positioned. I woulda gone diy, just liked the brand name idea better. Its bad enough people look at you funny when you have non brand mods, its even worse when its diy.
Users browsing this forum: No registered users and 93 guests
