98 evo gold
16bit
Vehicle: NB8A - Supercharged
98 evo gold
Postby 16bit » Thu Dec 18, 2008 11:38 am
stock for now.
16bit
98 evo gold
Postby 16bit » Fri Dec 19, 2008 11:34 am
thanks - yeah i only bought them for asthetic and weight reasons.
CapitalF
Vehicle: NA6 - Turbo
98 evo gold
Postby CapitalF » Fri Dec 19, 2008 4:20 pm
I really like it from the front, but the arse and side don't do it for me. Nice wheels. What? No CF hardtop to match??
Im -positive- the grunt factor would get me over the looks. :-D
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
16bit
98 evo gold
Postby 16bit » Tue Jan 20, 2009 8:01 pm
just got some nicely heat cycled semis for this years track days. Advan A048 in 225 50 15. they are seriously wide. I will be bringing these out at the second time I go as I would like to see the difference between these and my do1's with my current setup.
d-mag
Road Track Rally
Vehicle: ND - Turbo
98 evo gold
Postby d-mag » Wed Jan 21, 2009 6:38 pm
Don't waste your time on streets while on the track if you've got some semis just sitting there. One of the best mods you can do to lower times IMO. Jump straight in man. :wink:
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
16bit
98 evo gold
Postby 16bit » Wed Jan 21, 2009 7:20 pm
do1's are semis. they are the older style dunlop semi slick that has been replaced by the do3
d-mag
Road Track Rally
Vehicle: ND - Turbo
98 evo gold
Postby d-mag » Wed Jan 21, 2009 7:56 pm
Haha, my bad. :lol: BTW, I had AO48s on a previous ride and they're an awesome tyre.
16bit
98 evo gold
Postby 16bit » Wed Jan 21, 2009 9:36 pm
werd - if they are good enough for the hks cr230 something something time attack evo they are good enough for me!!! i am hoping for about .5 of sec per lap improvement from these over the smaller older tyres. big i know but will be interesting.
16bit
98 evo gold
Postby 16bit » Sat Jan 24, 2009 2:15 pm
finally got my sparco in after trying 3 ways the last worked - as is to be expected. After trying to come up with a way of making a braket to mount to the stock rails and then side mount to the seat I gave up when i realised i would have to cut the seat belt bit a little. So one night trying to get to sleep another idea hit me. I thought I would bolt a bit of 40mm square aluminium bar to the rails creating a box then mount the seat to the aluminium bar. after a little trial and error it worked. And me not being the tallest man alive it also solved the problem of the seat being too low! i will post pics soon.
16bit
98 evo gold
Postby 16bit » Wed Feb 11, 2009 12:32 pm
a few updates. I swapped the aluminium bar to gal steel of the same measurements for the seat. I have also braced the front end so the slitter is supported by more then just the front bar its self.
I also just organised to purchase a wing for the track next week.
http://www.buddyclubuk.com/wing.htm
My problem is now do I drill my carbon boot lid or do I just put it on my stock one?
98 evo gold
Postby Jeo » Wed Feb 11, 2009 3:16 pm
Drilling carbon sure doesn't seem undo-able, but it would look much better :)
Sidenote, are you using bonnet pins?
And any chance of engine bay pics?
16bit
98 evo gold
Postby 16bit » Wed Feb 11, 2009 3:20 pm
no bonnet pins. there is a provision for them I think like an outline of sorts. I am doing my new air box on the weekend then I will give it a bit of a clean and take some pics.
16bit
98 evo gold
Postby 16bit » Thu Feb 19, 2009 1:08 pm
just got a wheel alignment done
Front:
Caster left 5.96 - Caster right 5.39
Toe 0.5 out per side
Camber 2.3neg per side
Rear:
Toe 0.4 in per side
Camber 3.1neg per side
Wait to see how it goes at the club track day on the 5th of march.
16bit
98 evo gold
Postby 16bit » Fri Feb 27, 2009 5:08 pm
just ordered a sparco 4pt harness for thursdays track day. can't wait!
16bit
98 evo gold
Postby 16bit » Mon Mar 02, 2009 12:27 pm
harness has arrived and I will be installing tonight!!!! thanks to Peninsula Race gear - great price and service as always.
