Blow by/Catch can
d-mag
Road Track Rally
Vehicle: ND - Turbo
Blow by/Catch can
Postby d-mag » Sat Jan 10, 2009 11:58 am
Just wondering if anyone else is getting blow by?
I took my BOV off the other day and noticed oil coating the inside of the pipes, so I bought a catch can.
Has anyone else had this problem or installed an aftermarket catch can?
Must just be me.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
bark
Vehicle: NA6 - Turbo
Blow by/Catch can
Postby bark » Thu Jan 15, 2009 8:29 pm
I've installed an aftermarket catch can. Mine is connected to to the pipe out of my rocker cover as well as return back into the air intake pipe. I can't say I've noticed any blow by in my car...
Maybe a seal on your turbo is starting to let go and is weaping thus allowing oil to circulate through??
Garry
Blow by/Catch can
Postby Garry » Fri Jan 16, 2009 10:21 pm
My car has always had a bit. I've been told by several sources it's normal. Replacing the turbo didn't change anything.
Blow by/Catch can
Postby Okibi » Fri Jan 16, 2009 11:45 pm
Apparently its pretty common with TX3/323 turbo owners.
THE REAL BORIS
Blow by/Catch can
Postby THE REAL BORIS » Tue Jan 20, 2009 12:24 am
I had to fit mine as soon as I fitted the AEM inlet upgrade. I had to put it back to stock in a hurry before it was installed!!!! The original intercooler was in a mess too.
I have only emptied it out once in 10,000 miles. :D
This was early days and before I sealed off the original little inlet/outlets seen here joined together with the clear hose. I certainly recommend that you use hose of the original Mazda diameter for the best results.
Users browsing this forum: No registered users and 78 guests
