SC12 supercharger on an NA8
- Learner Driver
Just looking at the possiblity of using an SC12 supercharger from a Toyota 4AGZE engine.
On the Toyota the blower sits between the throttle body and inlet manifold, however my plan was to mount the blower where the A/C compressor is mounted. ie a hot side setup on the air intake side of the TB.
Anyone see any major problems other than plumbing and ecu, I currently runa megasquirt pnp.
Thanks
Dave
Thanks
Dave
pretty fly for a white car
see last post on the following thread:
viewtopic.php?f=29&t=34551
where Okibi mentions that Roger Trethewey has an SC13 mounted down there on his track car. It's accompanied by a photo.
- fastfreddygassit
- Waitin' for a mate
Do you have the SC12 yet? I have a M45 (from a Kompressor) that could possibly be available at the right price.
- Learner Driver
I'm looking at 2 at the moment, but it's early days yet. What did you have in mind for the M45.
- fastfreddygassit
PM me and we'll talk turkey...
'gobble, gobble, gobble'...
Any supercharger from a 4AGZE will be around 20 years old (when did they last appear? Trueno, Sprinter).
- daffyflyer
I have had similar ideas with an SC14, so any info that can be offered would be awesome
Daffyflyer, Peter Dowling at Autotech Services 11-13 Collie St Fyshwick (02 6280 5061) might be worth talking to - he mentioned to me he thought the Toyota SC would go well on an NA8 MX5.
- daffyflyer
93_Clubman wrote:Daffyflyer, Peter Dowling at Autotech Services 11-13 Collie St Fyshwick (02 6280 5061) might be worth talking to - he mentioned to me he thought the Toyota SC would go well on an NA8 MX5.
Ooh, ta will give him a ring
- daffyflyer
Oh, By the way www.autospeed.com has a pretty good article on doing your own custom supercharger setup (in their case on a Prius! )
Btw, should add that it would also be worth having a chat to Russellb on this forum from Carco at Belconnen. Lots of experience with MX5s & also with SCing - some of his work is posted here.
There used to be a yellow race spec miata on cardomain that had a cold side mounted sc12 or sc14 mounted on it. I tried contacting them with no joy. Maybe you might have more luck. It was a beast and done pretty well.
- rhysk
SC12 is far too small, even the SC14 is not worth bothering with unless you only want 100 rwkw.
They're at least 17 years old and difficult to rebuild.
I disagree Rhysk.
The SC12 was made for the 1600 Toyota(MR2) from memory and the SC14 for a 2 litre 6 cylinder.
As far as I know the rotors also have coatings on them to prolong life. Japanese built parts especially for Toyota tend to last quite a while. There are even a lot of old Holdens using these supechargers on 6 cylinders with good results.
At about $350 it makes a cheap project if you have the time.
My mate had a second hand SC14 on his 3.8lt commo, it had a custom made pulley to overspin the charger and made about 10psi. It was 100% reliable for over a year and probably put out about 180kw at the wheels.
An intercooled SC14 would be great on a 1.8.
Users browsing this forum: Bing [Bot] and 249 guests
