Good place to mount tweeters on an NA.
Locutus
Postby Locutus » Sat Jan 10, 2009 10:16 pm
Juffa wrote:The Neo Green LEs that I have seen have had the tweeters mounted in the upper door trim as shown in the red trimmed LE.
yep that's where mine are mounted in my 97 LE as delivered.
Jimmy
Postby Jimmy » Sat Jan 10, 2009 11:44 pm
Juffa wrote:The Neo Green LEs that I have seen have had the tweeters mounted in the upper door trim as shown in the red trimmed LE. I take it yours are not mounted there Jimmy?
Nope, the 90/91 Neo Greens didn't come with tweeters. They came with the CD player and headrest speakers. Maybe its an NA8 LE option?
Mr_Q
Postby Mr_Q » Sun Jan 11, 2009 9:49 am
I think some of the later Japanese NAs may have had the tweeters in the door trim too. I got some from an import which had them.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
CheyneX5
Postby CheyneX5 » Sun Jan 11, 2009 5:34 pm
Well, i just bought my new splits. They are Cadence FXC-6K 6.5" splits With tweeters and 2-way crossovers, power is 70 watts RMS with a peak of 300 watts.
http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=92&idproduct=472#details
They are a great sounding system, being a bit of an audiophile i wanted something good but had limited cash, i listened to some of the JL gear and some Alpine Gear and they were in the $4-500 mark, these Cadence splits were $219 (got them for $90) and they sound arguably better than the others i listned to. I wont be able to judge until i hear them in the 5 though. But hey... they are bound to sound better than my sony splits i had that retailed for $80.
Cheers Guys.
90' NA6 - Classic Red
crzymx
Postby crzymx » Mon Jan 12, 2009 1:16 am
Wouldnt a 2 or 3 way speaker work aswell?
DIY is the new black!
CheyneX5
Postby CheyneX5 » Mon Jan 12, 2009 8:48 am
they are 2 way...
Postby Jeo » Mon Jan 12, 2009 1:01 pm
crzymx wrote:Wouldnt a 2 or 3 way speaker work aswell?
Multiple speakers in the one cradle will always be a compromise. Some argue that they work, but they will always be a step down compared to the same speakers aranged as seperate components.
crzymx
Postby crzymx » Tue Jan 13, 2009 1:56 am
how does 2 way with splits work?
CheyneX5
Postby CheyneX5 » Tue Jan 13, 2009 9:27 am
Oh, woops :oops: got my words mixed up. they are 2-way Component speakers.
mr_rotary
Postby mr_rotary » Tue Jan 13, 2009 12:41 pm
Mr_Q wrote:I think some of the later Japanese NAs may have had the tweeters in the door trim too. I got some from an import which had them.
I have installed mine in about the same spot.
CheyneX5
Postby CheyneX5 » Tue Jan 13, 2009 12:53 pm
How did you do it Mr_Rotary? Did you need to cut a hole in the crash pad? and i assume from there you just run the wires down the doors as normal right?
mr_rotary
Postby mr_rotary » Tue Jan 13, 2009 2:20 pm
CheyneX5 wrote:How did you do it Mr_Rotary? Did you need to cut a hole in the crash pad? and i assume from there you just run the wires down the doors as normal right?
Spot on. Mine are Alpine Type X so they are a lot smaller than what's pictured there so blend in a lot nicer. I'll take a pic later and upload. Main speaker also fits nicely behind the grill, not on top like some bodgy's on here :wink:
mr_rotary
Postby mr_rotary » Tue Jan 27, 2009 9:31 pm
