Juffa wrote:The Neo Green LEs that I have seen have had the tweeters mounted in the upper door trim as shown in the red trimmed LE.
yep that's where mine are mounted in my 97 LE as delivered.
Juffa wrote:The Neo Green LEs that I have seen have had the tweeters mounted in the upper door trim as shown in the red trimmed LE. I take it yours are not mounted there Jimmy?
crzymx wrote:Wouldnt a 2 or 3 way speaker work aswell?
Mr_Q wrote:I think some of the later Japanese NAs may have had the tweeters in the door trim too. I got some from an import which had them.
CheyneX5 wrote:How did you do it Mr_Rotary? Did you need to cut a hole in the crash pad? and i assume from there you just run the wires down the doors as normal right?
