mx52nv wrote:Well apparently there is a tool bag up there already
by that, did you mean the lady?
see what happens when you put a woman in space? everything goes wrong.
TheMissus wrote:It looks like it is really starting to come together ...
orx626 wrote:how's the new donk?
orx626 wrote:TheMissus wrote:It looks like it is really starting to come together ...
...yes the crane access system has come together well Michelle!!!
...oh you mean the car is really starting to come together?!?
...it will once I get a clear run at it!
ps. how's the new donk?
orx626 wrote:thunderbird2 wrote:What's the 'up close' lift on that thing? And is it just the angle of the shot or does every axle steer?
It's a Grove GMK-7450....which means that it is a 7-axle, 450 Tonne All-terrain crane. Only the 2nd one in Australia. Melrose cranes in Sydney have the first one.
Yes, every axle steers so that the crane can crab sideways if required.
Okibi wrote:Stunning work as always, so when are you going to make us NA/NB owners top hats and a pair of brackets for RX7 brakes to fit inside stock NB wheels?
Fatty wrote:Okibi wrote:Stunning work as always, so when are you going to make us NA/NB owners top hats and a pair of brackets for RX7 brakes to fit inside stock NB wheels?
yeah, and could you make sure that they'll fit with 14 inch NA rims too? ta.
Okibi wrote:IF they can build some that fit inside the stock 15s without a need for a spacer that use DBA rotors and light weight hats they'll be able to make bulk coin
Users browsing this forum: No registered users and 216 guests
