NB8C lights fit NB8A?
Postby Okibi » Wed Jan 04, 2006 8:07 pm
I'd love to know how much they cost.
Sounds like you only need to cut about 5mm of the bumper near the insides of the lights to fit the NB8B SE lights.
You will have an extra 1mm gap in the middle below the lights.
Sounds like a pretty easy job with a dremel and a file, just take your time so no mistakes.
You'd also need the correct plugs to wire in the NB8B lights.
Dan18B
Postby Dan18B » Wed Jan 04, 2006 8:37 pm
I have done the conversion. You need later front lights, new parker light adapters, new high and low beam adapters and new two front splash guards for the left and right wheel arches. Beast to get the fog lights from IL motorsport, not geniune, but about half the price. All up it will cost around $500 per headlight for NB8B style + globes,$250 front bumper, $500 for painting, $300 for fog lights, $100 for wiring plugs (9001 and 9002 high and low beam adapters are expensive and could only be sourced from US), $90 for mazda fog light switch, $100 for splash guards. $2440 all up, not cheap but looks good.
Andrew
Postby Andrew » Wed Jan 04, 2006 8:38 pm
Dan18B wrote:$2440 all up
:shock:
irwin83r
Postby irwin83r » Wed Jan 04, 2006 8:44 pm
and the little pig said 'F$&@K DAT!"
ill just get the lights and wiring and bodgy my ass off haha. though if i ever get a body kit ill get them to make it for SE lights.
though thats another thing thats on the back burner
:P
thanks guys
Postby Okibi » Wed Jan 04, 2006 10:47 pm
Well i have the NB8B front; i still need to get it painted.
I'll just dremel 1mm off the middle bit under the NB8A lights and put up with the 5mm on the inside of the lights.
I don't need the fog lights, i have a much better use for those holes. :twisted:
Although i could DIY some fog lights pretty easily and i have an NA6 mazda foglight switch (without the light in the switch). :?
Will i need the "two front splash guards for the left and right wheel arches" ? what's the difference between the NB8A ones?
Bevan
Postby Bevan » Thu Jan 05, 2006 10:38 am
:shock:
.........Image
Just upgrade to an NB8B...
irwin83r
Postby irwin83r » Sat Jan 07, 2006 1:22 pm
as i said before bevan. if i had the cash i would :D
im sure i could bodgy my front bar to take the SE lights... its amazing what bog and paint will hide :shock:
haha
crzymx
Postby crzymx » Tue Dec 16, 2008 1:31 am
I remember the guy from mx5plus offering a 600 hundred dollar conversion?
DIY is the new black!
mx52nv
Purple Porsche Eater
Postby mx52nv » Tue Dec 16, 2008 8:48 am
Hey newbie, you are replying to a thread 2 years old.
irwin83r
Postby irwin83r » Wed Dec 17, 2008 7:40 pm
two years on and im still here... and! i still havent put an se front end on...
have all the bits now just need a painter :P
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Dec 28, 2008 2:31 pm
This is a NB8A front bar with NB8B headlight...as you can see not a good fit...I am planning to fit NB8B front on the green car when I acquire another headlight and a nose cone.
Tail lights..B top A bottom.
MX5CHIC
Postby MX5CHIC » Sun Dec 28, 2008 4:43 pm
Thought of Aftermarket Headlamps? - NB8A
TieNN89
Postby TieNN89 » Fri Jan 02, 2009 1:15 am
:O where can i get my hands on them lights (projectors :D)
how much?
MX5CHIC
Postby MX5CHIC » Fri Jan 02, 2009 8:53 am
I don't know if they are available in Australia anymore, but here are some links for info :
http://www.e-styling.co.uk/scpro/estyli ... urer=Mazda
http://morette.com/products/HEADLIGHTS/ ... /HLMX5.htm
I bought them new via an EBay store located in Melbourne, cost was $294 for a pair.
OKIBI posted pics of another brand to fit NB8A in another area of the forum.
Postby Okibi » Fri Jan 02, 2009 1:44 pm
Lou I have a feeling those NB8B headlights aren't sitting correctly against that bumper.
Didn't you use to have an NB8B fron with NB8A headlights? I have about a 1cm gap on the inside of the NB8A headlights with the NB8B bumper.
So i'd expect those headlights need to be moved further towards the centre of the car. NB8A lights are also a bit more curved at the bottom.
As Lou pointed out the NB8A/B tails lights are an easy swap and a few of us have done this.
