Redline MT-90 or MTL 1994 5 speed
Damo
Postby Damo » Wed Dec 24, 2008 1:12 am
wun911 wrote:Im using MT90 from the GB ages ago quite happy with it...
So am I. I only put it in recently and it's done what the manufacturers claim. Quicker, easier shifting. Good stuff.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
Patty
Postby Patty » Wed Dec 24, 2008 10:23 am
AZNTieN wrote:How many bottles do you all buy?
Redline says I need 3 bottles for the gearbox :shock:
because the gear box requires 2L and Redlines bottle is 1 US Quarts = 0.946L
I'm thinking of getting the MT-90
What does everyone use in there diff?
I've got MTL in mine. Bought a large red bottle from Autobarn, I forget what volume it was.. 3.8L or something. It was enough for 1 change, not enough for 2.
Anyway, the difference was pleasing. Sometimes though I still find it almost impossible to shift up into 2nd when it's cold but it's usually only the first shift after it leaves the garage.
Grace Green NB8A
fattima
Postby fattima » Wed Dec 24, 2008 10:37 am
Two bottles is enough for the gear box. If you are changing the oil in the shift turret you need more, but I think it would be a waste to use MT90 in the turret. I was running Royal Purple oil before the Redline, the Redline has improved the shift when cold.
For the diff (std not LSD) I'm using a Castrol oil but can't remember what one :oops: It is nothing flash, maybe epx 80?
wun911
Postby wun911 » Wed Dec 24, 2008 1:57 pm
Two bottles of MT90 was enough for me (6spd)
every ounce counts
Postby 93_Clubman » Wed Dec 24, 2008 9:09 pm
Did 5sp GB & Torsen with 3 bottles.
