grump wrote:A pod filter is illegal..
In W.A. you can get a permit to mount a pod filter. They just check and make sure it's all attached securely.
grump wrote:A pod filter is illegal, I'm not sure but I think that if your air intake is outside the engine bay it is alright. the reason a pod filter is illegal is because if your car should backfire through the filter it could cause an fire in the engine bay. I think the modern filter boxes probably have some sort of baffle system built into them to stop any such occurence. I think this baffle system could be the restriction that makes a pod filter more effective. just a thought.
grump wrote:the mania pod filter is enclosed in an airbox with a tube off the intake side which goes through the firewall. My old ski boat motor, 350 chev, used to backfire through the carb all the time.
You had to hit the starter to suck the flames back into the carb to put the fire out. scarry to the uninitiated, but you got used to it.
GP wrote:I didn't bother with the hole thru the firewall, Not very much advantage in doing that. I did it remove the airbox restriction which Improved performance/fuel economy.
Are you suggesting that the CAI is not neccessary?
GP wrote:Are you suggesting that the CAI is not neccessary?
I'm just saying that drawing air from in front of the windscreen gives little to no Improvement over just drawing air from under the bonnet.
I am planning on ducting air from the front of the car one day.
The abreviation CAI I find optimistic, I prefer AAI (Ambient Air Intake)
GP i'm sure if you go back through the posts you will find evidence that proves that a cowel intake makes a noticible difference. It won't make any difference where you pick up your air from under the bonnet, it will be hotter than the air outside your bonnet. the gap between the bonnet and screen is a high pressure area , so it is a good place to pick up your air from.
