Advice for new turbo setup....
ben, t25 and t28 turboes both use exactly the same flange. they are interchangeable AFAIK .
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Just a word of caution, check the amount of auxiliary outputs of the Link before you do anything. Their packaged computers (not sure of the model designation) sold with the turbo kits did not have enough outputs to run a MAP sensor and boost control at the same time. The more outputs, the better mate - you can never have enough.meanmx wrote:As for the OP's original question you can definately look into AVO. They use the Link computer. I haven't got one but everything they have done on my car so far has been brilliant.
Most of the better ECUs have a dedicated boost, stepper motor and idle speed control among other functions.
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
As I posted up originally, I chose the tuner first, AVO. I went for the Link ECU because that's what the guys at AVO use, recommend and have experience tuning.
This is the ECU I got.... http://www.linkecu.com/products/engine- ... er/g4storm
I also have an external Boost controller, just to be on the safe side.
MX5 Wanted. SE or NC (forced induction preferred )
Been looking at the Haltech E6X. Its got a built in MAP sensor good to (1.5bar), but it supports external MAP sensors. wondering if anyone knows a tuner, prefebly in melbourne, but i'll drive to Sydney or Adelaide is someone can suggest someone.
Heres a link if anybody wants a look
http://www.tweakit.net/shop/product_inf ... ucts_id=87
Cheers again,
Matty
Cheers again,
Matty
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
I have one of the ealier model miatalink ECUs from link in my 5. It has been upgraded with a later chip from Flyin' Miata. It is currently supporting a link MAP sensor, knock sensor, water/air temp sensors and when I get around to setting it up properly, a electronic boost control.
As far as ECUs go it is limited when compared to the current ECUs such as the megasquirt and other brands out there. Having said that I bought it because it has a big user base and FM provide good support of their code.
As already mentioned, and from what I can you have heeded make sure that which ever ECU path you go down make sure you find a decent tuner and support for it.
J
J
- d-mag
- Road Track Rally
Matt, these guys are listed as an agent for Haltech. A guy I know had his car tuned there, he said they were pretty good.
http://www.gdperformance.com.au/
No affiliation.
No affiliation.
- Tedsmx5
- Vehicle: NA8 - Supercharged
Matt,
I have a Adaptronic ecu in my SC NA8 and am very happy with it's performance. The price is good to!
http://www.adaptronic.com.au/salescomm.php
Ted
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
Thanks for all the advice everyone!
I found a tuner that does haltech and Link ECU's in melbourne, so ill probably go with the Link, he says they're better than the Haltech's
Matty
Matty
hey matt,
i was at maztech in preston this afternoon. i had them do some work on my car, they were very quick and from the looks of it the workmanship is good.
anyway anthony and i got chatting about ecu's and after listenning to him talk for a while this guy clearly knows his stuff. they are a microtech dealer, a motech dealer and he has lots of experience with many other ecus. this guy gets flown interstate and overseas to tune cars for people, so clearly he knows a thing or 2. i would suggest you go have a chat to him as well. i've seen plenty of positive comments about his tuning from people on this forum in the past. eg i know pcmx5 had an ecu installed and tuned at maztech, probably worth shooting him a PM for his thoughts.
- Rotary
About 10-15 years ago Anthony(maztech) had the fastest rotary in the country, and he held that title for some time 2 or so years from memory.
So he would have to know his stuff very well especially in the area of F/I and tuning.
Good point guys, I forgot all about them.....my mate used to own an rx4 with a 13b and he ran a microtech ecu.
Cheers again for the help.
glen73 was also very happy with Anthony at Maztech - his threads follow - then just type in Maztech into "search these results" to get the threads where Maztech is mentioned - there's 6 of them.
search.php?st=0&sk=t&sd=d&sr=topics&author=glen73&ch=0
Users browsing this forum: Google [Bot] and 41 guests
