front bumper removal nb8a
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Dec 04, 2008 8:56 pm
just wondering if anyone has instructions on removing the front bumper on an nb8a? if not I will just have a crack.
Garry
Postby Garry » Fri Dec 05, 2008 8:09 am
From memory, there's a few 10mm bolts on the metal part of the bumper cover near the radiator support under the bonnet, 2 phillips head screws at the top rear of the bumper cover that hold it to the guards, 6 or so poxy plastic turn and release clips holding the guard liners on, 2 10mm nuts holding the number plate bracket on, 2 more poxy turn and release clips in the top of the mouth, 3 triangularish shaped clips at the bottom of the mouth and some assorted screws underneath the bumper cover holding it to the splash tray. Then slide the bumper cover forward and it should fall off in your hands. I may have forgotten a couple of fasterners but thats most of it.
A couple of tips...
There's a good chance you will need 3 new clips that hold the bumper cover to the mouth part near the bottom of the radiator. The triangularish shaped things. They are made of really brittle plastic and I haven't yet managed to remove them without breaking them.
An extra pair of hands helps when you're putting it back together.
16bit
Postby 16bit » Fri Dec 05, 2008 9:38 am
thanks mate - may have a go on the weekend.
Postby Okibi » Fri Dec 05, 2008 9:56 am
Yeah think Gary is spot on, its so easy I forgot how I did it. :oops:
I broke 1 of those triangular clips too.
Postby sliq » Fri Dec 05, 2008 12:06 pm
Garry wrote:From memory, there's a few 10mm bolts on the metal part of the bumper cover near the radiator support under the bonnet, 2 phillips head screws at the top rear of the bumper cover that hold it to the guards, 6 or so poxy plastic turn and release clips holding the guard liners on, 2 10mm nuts holding the number plate bracket on, 2 more poxy turn and release clips in the top of the mouth, 3 triangularish shaped clips at the bottom of the mouth and some assorted screws underneath the bumper cover holding it to the splash tray. Then slide the bumper cover forward and it should fall off in your hands. I may have forgotten a couple of fasterners but thats most of it.
it's pretty scary you know exactly where everything is with detail, and this is all from the top of your head!! :shock:
RG.net
Postby RG.net » Fri Dec 05, 2008 5:51 pm
you put all that gear on the car without taking the bumper off?!?!
16bit
Postby 16bit » Fri Dec 05, 2008 8:16 pm
you would be supprised how patient I am
RG.net
Postby RG.net » Sat Dec 06, 2008 10:07 am
16bit wrote:you would be supprised how patient I am
haha, good on ya! :D
Sean
Re: front bumper removal nb8a
Postby Sean » Mon Dec 03, 2012 7:02 pm
Old topic revival right here...
Thanks Garry!
Just used this.
Users browsing this forum: No registered users and 238 guests
