mx52nv wrote:Totally agree with the philosophy there mate. Just so you knowd-mag wrote:As I posted up originally, I chose the tuner first, AVO.
Could you explain why this is safer? I just wanted your thoughts on the matter. I think this is the whole point of having a turbo section for the forum, so we can all share our thoughts on the subject to make this a wholly informative and educational experience for the not-so-initiatedd-mag wrote:I also have an external Boost controller, just to be on the safe side.
Actually should we just start another thread? Okibi, what do you reckon?
MX52NV and d-mag chat about ECUs and boost control
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
MX52NV and d-mag chat about ECUs & boost control
Thank you Okibi for making this thread. A bit of background first:
I think d-mag and I were discussing the merits of aftermarket ECUs and also the Link computer.
I made the comment that one should make sure there are plenty of auxiliary outputs available and dedicated boost, idle up and starter motor controls. This was because some packaged Link computers (that are sold with the AVO turbo kits) do not do certain important functions like read MAP sensor and control boost at the same time.
d-mag then specified his version of the Link ECU (with a website link I think) and that he was using an external boost controller as his post above, which brings us to this topic
Okay, guess it is over to d-mag now
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
MX52NV and d-mag chat about AVO turbos
ROFL! This is hilarious Dave
Good summation mx52nv.
Your right, the packaged units aren't too flash, the stand alones are much better.
Why I got the external boost controller? A previous car (still have it actually) had over-boost issues even though the ECU it had had a boost controller. Is it necessary with the LINK G4? Probably not, but as the internals are still stock I didn't want to risk it (paranoia, I know. I blame the pot from my teenage years
Also, the Turbosmart duel stage boost controller I got allows me to have this nifty James Bondesqe toggle switch for high/low boost.
MX5 Wanted. SE or NC (forced induction preferred
- mx52nv
- Vehicle: Non MX-5
ROFLMAO!!!
I have the same aircraft toggle switch
Except mine is for anti-lag
Anti-lag = 'pop, pop, bang, bang' at the lights?
Question. I thought a boost controller (manual or electronic) only allowed you to increase boost above the level allowed by the wastegate actuator?
I installed one with my earlier model link ECU and had at least one major over boost incident before I disconnected it.
J
J
- ampz
- Vehicle: NA6 - Turbo
That's right Juffa...
I had a hose blow off my last one and at the time had no overboost protection (smart)...
I since changed that with the replacement engine
Huh?
- mx52nv
- Vehicle: Non MX-5
Well yes to the "pop, pop, bang, bang" but definitely not the the lights. Unless of course you mean the 'Christmas' tree lights at the start of Motorkhana eventsbruce wrote:Anti-lag = 'pop, pop, bang, bang' at the lights?
Correct. The spring rating (PSI) will determine the minimum boost that the actuator will allow before opening its valve and venting the positive pressure.Juffa wrote:Question. I thought a boost controller (manual or electronic) only allowed you to increase boost above the level allowed by the wastegate actuator?J
