Wheel nuts
Fuzzlet
Wheel nuts
Postby Fuzzlet » Mon Dec 01, 2008 5:48 pm
Whilst doing a test fit of my track rims I ran into a problem - my wheel brace is too large if I want to use the SE's original wheel nuts. The nuts fit ok, its just the hole on the rim isnt big enough to fit the brace. Anyone know of a decent brand etc that are smaller than the standard nuts?
grump
Wheel nuts
Postby grump » Mon Dec 01, 2008 6:09 pm
Fuzzlet, I have found a long breaking bar and a longreach socket do the job. I don't think you will get a thinner wall thickness than a good quality socket.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Wheel nuts
Postby d-mag » Mon Dec 01, 2008 8:42 pm
Same thing happened to me on a previous car, I pulled up to a Super Cheap grabbed a few braces, took them out and test fit them all 'till I found one that fit.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
bigdog
King of the kennel
Wheel nuts
Postby bigdog » Mon Dec 01, 2008 10:06 pm
I use internal hex wheel nuts with a 12mm hex half inch drive socket (not the key that comes with the nuts). No chance of scratching the wheels this way :D
wun911
Wheel nuts
Postby wun911 » Mon Dec 01, 2008 10:54 pm
I file mine down so it could take a smaller socket...
every ounce counts
Fuzzlet
Wheel nuts
Postby Fuzzlet » Tue Dec 02, 2008 12:01 am
Well after chatting with the previous owner of wheels he said he ran 17mm lightweight nuts, and apparently with a 19mm socket he could use standard nuts. The SE's are bigger than this, so looks like a second set of nuts are in order....will mean I can get some lightweight ones :P
As for scratching the wheels - not really a problem, since the (green...) paint is already chipping off, and I'm planning on sandblasting them when these tyres wear out
Fuzzlet
Wheel nuts
Postby Fuzzlet » Tue Dec 02, 2008 5:10 pm
Well I have ordered some new (lightweight) wheel nuts. Should be here within a few days thankfully
TieNN89
Wheel nuts
Postby TieNN89 » Tue Mar 31, 2009 1:07 am
what did you get?
any pics?
Fuzzlet
Wheel nuts
Postby Fuzzlet » Tue Mar 31, 2009 2:12 am
Buddyclub lightweight nuts. Not cheap, not lighter than stock nuts (infact weigh almost double), however they do fit with these rims
TieNN89
Wheel nuts
Postby TieNN89 » Tue Mar 31, 2009 11:09 pm
Fuzzlet wrote:Buddyclub lightweight nuts. Not cheap, not lighter than stock nuts (infact weigh almost double), however they do fit with these rims
ha misleading then
lightweight nuts that weight double stock nuts
Fuzzlet
Wheel nuts
Postby Fuzzlet » Tue Mar 31, 2009 11:29 pm
Yea if these are the 'lightweight' nuts I'd hate to see the 'standard' ones then. Having said that these ones are around 50mm long, meaning they fit down the 20mm cutouts for the wheel nuts and I can fit a 17mm socket over them to do them up
wun911
Wheel nuts
Postby wun911 » Wed Apr 01, 2009 1:50 pm
I would be deeply cut thats very deceptive; like saying 'superlite wheels' that are 7 kg each.
There should be a law against such false claims in advertising.
I would consider any nut under 25 grams to be considered as 'lighweight'.
every ounce counts
TieNN89
Wheel nuts
Postby TieNN89 » Wed Apr 01, 2009 11:17 pm
any idea what the weight for the stock ones are?
TieNN89
Wheel nuts
Postby TieNN89 » Thu Apr 02, 2009 10:13 pm
33gram are my stock ones
Wheel nuts
Postby hks_kansei » Fri Apr 03, 2009 1:57 pm
will lightweight nuts make ANY difference that is noticable?
the difference overall between a 33g nut and a 70g nut is 592g for the whole car, or 148g per wheel.
148g right in the centre on the wheel is likely to make ƒü¢k all difference!
you can save about the same amount of weight by skipping lunch!
ok, finished ranting.
I'll show myself the door to this thread.
