Intermittent central locking fault.
crzymx
Postby crzymx » Tue Nov 25, 2008 4:39 pm
As the topic suggests, i have an intermittent central locking fault which means my passenger wont always lock when the drivers side door does. This is on and off as sometimes is works for sometimes then stops, sometimes it works every second lock. Someone pleeease help me as iam going insane, i have pulled the trim off and tried fiddeling with the connections and nothing seems to work.
Plus i am trying to buy a keyless entry kit however i cant install one untill i fix this problem.
DIY is the new black!
blue_na
Postby blue_na » Wed Nov 26, 2008 9:06 am
Maybe one of the motors has worn out?
The emotion of motion... Zoom-Zoom!
crzymx
Postby crzymx » Wed Nov 26, 2008 10:41 am
Do you mean actuator? I doubt it, well i hope not. But when it does work it works fine so im thinking its a connection.
MX5CHIC
Postby MX5CHIC » Wed Nov 26, 2008 11:01 am
Take your right door trim off and check the tension of the rod which runs to your door handle / lock. It may be too tight or too loose which will affect the slave switch.
If this does not make sense, just loosen of the door handle rod then test the locking and unlocking operation via your key in the door - I had to make adjustments when my door locks played up.
Postby Okibi » Wed Nov 26, 2008 11:23 am
Mine had this problem and it's back again.
There's a little electronic magnet in the passenger side actuator, the part it needs to attract is too far away (or the magnet is loosing it's strength).
Last time I adjusted it so the magnet wasn't so far away from the part it needed to attract, the problem is back and i'll have to pull things apart again.
All parts are well lubed and can move freely.
crzymx
Postby crzymx » Wed Nov 26, 2008 8:49 pm
Ok i can check mx5 chics suggestion, but as for you okibi i may need a picture or something. What do ya reckon?
Steampunk
Postby Steampunk » Fri Nov 28, 2008 11:09 am
Does it make the normal clicking noise, but it just doesnt lock/unlock?
If so, then as per MX5Chic's suggestion, it may be the clamps that connects the central-locking actuator rods to the locking mechanism rods has come loose. Easy fix if it is.
crzymx
Postby crzymx » Fri Nov 28, 2008 1:57 pm
Well basically, when i lock the drivers door, it makes a noise on that side but doesn lock the other. Get this, sometimes i unlock the door, get in and when i go to unlock the other door manually it unlocks by itself. Like its delayed.
Jace
Postby Jace » Sat Nov 29, 2008 10:59 pm
i have the same problem.
let me know when you get it sorted.
crzymx
Postby crzymx » Sun Nov 30, 2008 1:33 am
Haha if i do, you let me know if YOU get it sorted :)
Postby Okibi » Sun Nov 30, 2008 12:21 pm
I'll let you know if I get it sorted too. :lol:
sabretooth
Postby sabretooth » Mon Dec 01, 2008 1:39 pm
If there's a delayed action, then it's probably the master actuator. Otherwise, it's probably the control unit or slave unit in the passenger door.
Either rod adjustments or actuator replacements are necessary.
