New wheels and seat. Went to winton on friday and blew the power steering line and lost a couple of bolts from the turbo after a few laps. So couldn't race.
lightyear wrote:The dump pipe is shocking, the steel plate that bolts onto the back of the turbo just has a small pipe behind the turbine wheel, and the butterfly on the wastegate is hitting the steel plate. And it has 2 very tight 90* bends straight after the turbo to clear the firewall.
Boags'MX5 wrote:lightyear wrote:The dump pipe is shocking, the steel plate that bolts onto the back of the turbo just has a small pipe behind the turbine wheel, and the butterfly on the wastegate is hitting the steel plate. And it has 2 very tight 90* bends straight after the turbo to clear the firewall.
GReddy.
Users browsing this forum: Bing [Bot] and 1 guest
