Toyo R1Rs
Toyo R1Rs
so $200 per tyre eh?
how are these in the wet? also what is the tyre wear?
- bensale
Toyo R1Rs
yep, $200 fitted and balanced at Tyre power. The T1R's are $175. Both 205/45/16
Re001's are $210 fitted and balanced. Hmm, probebly leaning towards the bridgestones but still very interested.
www.othersideproductions.com
- bigdog
- King of the kennel
- bigdog
Toyo R1Rs
well... no standing water to test aquaplaning yet, but grip on damp roads is exceptional - way higher than the T1Rs and PZeros that I have run in the past. I think I'll need a track day to see how high their limits are. Tread blocks feel really soft, so I'm guessing they will wear very quickly, and they are no stiffer than the T1Rs - I'm running 0 toe on the front and can't feel any improvement in turn in, so they probably won't please those looking for ultra sharp steering (but I have never been bothered by this). $196 fitted per tyre at Blairs.
Toyo R1Rs
ahh...they are semi-slicks aye?
ok...might investigate others then =]
- bensale
Toyo R1Rs
stevesports wrote:ahh...they are semi-slicks aye?
No they are a soft road compound, semi slick construction. The wear rating is 140, compared to 220 for the re001's and 280 for the T1R's.
- 16bit
Toyo R1Rs
i have read on club roadster or miata.net that they are actually the same compound as the 888's and that the wear rating is nominal by the manufacturor. the guy claimed he worked with toyo usa in the development of the tyre. not sure how much truth is in it either way they are very very soft for a road tyre. federal rsr is 180
Toyo R1Rs
hmm....high wear vs higher grip compared to RE001
hmmmmm
hmmmmm
- Boags
Toyo R1Rs
16bit wrote:i have read on club roadster or miata.net that they are actually the same compound as the 888's and that the wear rating is nominal by the manufacturor. the guy claimed he worked with toyo usa in the development of the tyre. not sure how much truth is in it either way they are very very soft for a road tyre. federal rsr is 180
I've read that Toyo initially sent them out with chewing gum tread but they wore way too quickly so they changed the compound.
Either way; Toyo market them as an Ultra High Performance road tyre, NOT a road legal motorsport tyre.
Boags
- bensale
Toyo R1Rs
I just checked out the wear rating on my Turanza's, they are 140 Same as the R1R's and less than the re001's.... I'm really confused could someone please clarify for me....?
- bigdog
- bensale
Toyo R1Rs
hmm, ok then thanks for that. It seemed very odd that an allrounder tyre would wear at the same rate as something like the R1R. However, one would assume that Bridgestone would have a uniform measurement... or not?
- bigdog
Toyo R1Rs
$850 all up for 4 x 205/45x16 fitted, balanced, old tyres disposed of and a very comprehensive wheel alignment. That's why I took the punt rather than spend more on PP2s or Adrenalins. I have a spare set of rims and i figure if they are wearing too fast for daily use I'll swap them over and fit something harder.
Users browsing this forum: Bing [Bot] and 255 guests
