MX5CHIC wrote:
Ambient and Radiant heat (via headers) under the bonnet will transfer a percentage of heat to the intake tube, but become more negligable as the total volume of air through the tube increases, meaning that the intake air from outside will act to a degree to cool the intake tube thus overcoming some of the heat transfer, materials used also have an affect on this heat transfer.
That is exactly my line of thinking, the massive volumes of air should easilly counteract this heatsoak and therefore i did not bother with covering my pipework. but my experimentation proved there is some heatsoak somewhere. my testing on the gtech showed quite subtantial drops in outputs and mph for 1/4 testing. and when i last went to WSID, i had the perfect opurtunity to check this when they let me go on consecutive runs and my kph was 3 down on my results all night.
I do agree with the theory, understanding the flows and volumes within every engine i tune, and it is a massive volume of air, but there is something measurable going on, wether it is occuring more in the intake runners and plenum, or in my tubing after the TB i can't say with 100% certainty, but it is a very interesting topic.
I would surmise that most of it would actually occur within the Intake body, due to the large amount of Al(high thermal conductivity) used and large surface area of exposure through the runners. and may be negligible where that heat is not replenished ie, intake attached to Head. (would you say this where it is happening?)
either way starting of with cold air will make a big difference
