for wun
for wun
The watch
Hrmz I never really use mirrors when driving
I dont belive a little nissan micra beat me
http://www.natsoft.com.au/cgi-bin/resul ... 8.WIN.S5.Y
Yeah I will leave the seat in on driver training day, any help to get my time down would be really cool.
Is steve going to take his own advice and get on the track? Then maybe I wont be last lol!
every ounce counts
for wun
yeah i will. I'm actually getting new shocks + springs at the moment. In addition, i'll be looking at getting some 15' wheels so i can get access to cheaper tyres + lower unsprung weight.
- Matty
for wun
wun911 wrote:Hrmz I never really use mirrors when driving
maybe you should, doing 1:55s...
Well, isn't it obvious - they're so much lighter!
Forget the Micra - I can't believe you were within ~1 second of an EVO7...
- sabretooth
- AJ
for wun
sabretooth wrote:You should totally put hydrogen in your tyres. It'd be lighter than air.
doesn't do much for traction tho Geoff..............
XMX5 Rogues
for wun
a micro switch under your accelerator peddle that turns your altenator off when you put your foot right down. an altenator that is producing charge uses horse power.
- sabretooth
for wun
CJ5 before you so easily dissmiss something, do a little reserch, for example to produce 45 amps requires approximately a 2 hp generator. if your altenator is charging at 45 amps it is using 3/4 of a horsepower. If you are running a battery that is half charged and the altenator is working hard to charge it ,the altenator will draw horsepower from your engine. I used the mico switch system on a ski boat that won the Queensland drag ski title many years ago, and that had a 350 chev in it that was producing nearly 700 hp.
Users browsing this forum: No registered users and 226 guests
