Felix's NA6 Updated 15/01/09
- feel_ixx
Felix's NA 1991 mx5
Thanks MXHEVN!
I hope my car doesnt get any intake / overheating problems from this
Add me on msn I'll PM you my email
- Felix
- PUR157
Felix's NA 1991 mx5
The dreaded crap MX5 number plate bracket...
Nice work there...! and Nice pics too...
Oneness of Man and Machine
- crzymx
Felix's NA 1991 mx5
Nice handy work, buit definately need to move the number plate bracket. I can give you some advice if you need!
DIY is the new black!
- feel_ixx
Felix's NA 1991 mx5
crzymx wrote:Nice handy work, buit definately need to move the number plate bracket. I can give you some advice if you need!
Hahaha I was just getting used to the number plate, I kind of like it sitting at the bottom lip... anyone got pics of this?
- Felix
- crzymx
Felix's NA 1991 mx5
Theres a pic of a red NA with it in your thread
Its pretty easy to do, cost $0
- feel_ixx
- crzymx
Felix's NA 1991 mx5
dont know bout that, all i know is that you can easily bend down the existing brackets, you might need to go slimline though.
- feel_ixx
- -alex
Felix's NA 1991 mx5
:O
we may be matching if all goes well..!
Im going to look at a white na tomorrow
- feel_ixx
- feel_ixx
Felix's NA 1991 mx5
DIY front lip
What you need:
Saw / Wire cutters
Drill (not for drilling into body work)
Linear PVC thing --- similarly you can go garden edging is what people normally do. (still unsure of how they mount it sounds hard)
Spray paint + primer
Optional: Flexible rubber strip i.e. Garage door seal
How to:
1. Cut the PVC strip into the right length for the curve of the under part of the car's nose about 1650mm ( cut a little more just in case you can fine tune it later)
2. Since the PVC strip had a right angled tab running down it, this meant that I could simply bolt it on. Problem was, this didn't allow the PVC strip to bend properly, to fix this, I cut small V's onto the tab about 6cms apart all the way along
(Garden edging is completely flat so although it is easy to fit the curvature of the car, mounting it will be harder)
3. There are bolts that are already under the front bar which are connected to the black plastic housing under the car (see pics) so mark out where the bolts match up to the PVC strip tab and drill 6mm holes for each point. Do a install before you paint to see if everything is curving correctly.
4. Prime and paint
4.5 Purely optional, but as you can see the end of the lip doesnt sit flush with the cars original nose, here you may want to buy a strip of garage door seal rubber and place it on front of your PVC lip.
5. Install and done
Note: I ended up not doing the garage door seal thing, seemed too much effort and also the finish wasn't as nice as without it, instead I curved the end bits it looks fine just like that
What you need:
Saw / Wire cutters
How to:
4. Prime and paint
5. Install and done
- Felix
- bensale
Felix's NA 1991 mx5
Thats nice mate, you've got a real touch for the DIY stuff! Lokk forward to seeing to finished pictures of the lip!
www.othersideproductions.com
- crzymx
Felix's NA 1991 mx5
feel_ixx wrote:Whats slimeline?
I dont know if they do em in syd, but in melb we have slimline plates which are about half the width of yours.
- sliq
Felix's NA 1991 mx5
crzymx wrote:I dont know if they do em in syd, but in melb we have slimline plates which are about half the width of yours.
half the width? that must be a very short and stubby plate.... have u got a sample photo? maybe u were referring to the height?
Users browsing this forum: No registered users and 118 guests
