Cracking Radiator
Cracking Radiator
hey, just noticed the plastic pipe bit (sorry i am very mechanically retarded) at the top of the radiator has some cracking/stress marks... is this a sign of things to come?
Time for a new radiator? or can that top bit be replaced alone?
- Garry
Cracking Radiator
You can replace the top plastic bit but it's not all that much more expensive to get a full alloy radiator from Mania. As a reference I think my new top tank was a bit over $200 supplied and fitted after I removed the radiator from the car and took it to the guy.
Cracking Radiator
Garry wrote:You can replace the top plastic bit but it's not all that much more expensive to get a full alloy radiator from Mania. As a reference I think my new top tank was a bit over $200 supplied and fitted after I removed the radiator from the car and took it to the guy.
considering i'd have to pay postage to get it over here, do you think it'd be worth it? or should i just ring round n get the top tank replaced
- Garry
Cracking Radiator
It depends on the condition of the rest of the radiator. Luckily mine was in good nick. It was also an SP radiator and the guy that designed the SP cooling system recomended not to fit a thicker one (like Mania's) to an SP as it reduces the cooling system efficiency. So in my case it was a new radiator from Mazda *shudder* or getting mine repaired. Do a ring around and see what the prices are like in your area for new vs repair.
- Steampunk
Cracking Radiator
Around $80 for replacement top tank and clean from Red Devil Radiators.
It's a value-for-money fix IF the person who replaced it sealed it correctly. Mine started leaking after about 8 months.
Why not hunt around for a second-hand, low-mileage one as the going rate is around $100 or less. Boyracer has a couple doesn't he?
- Garry
Cracking Radiator
No idea how you got it done for $80. The tank alone for my car was around $150. The guy that did the job was shocked at the price of the tank. He said it was much more expensive than other cars he'd done. I rang several places and all were about the same money. Are NA top tanks cheaper to source?
- sliq
Cracking Radiator
thanks guys! seen boyracer's radiators for sale before (even bought one of the elec. antennas!) but forgot abt em hahaha
he's selling the SE rad for $100 more than the standard ones.. you reckon its worth it? i spose WA is bloody hot, but i dont track race, really just 'spirited' drives and no plans to turbocharge any time soon.. future mods would be CAI and exhaust
the standard one clearly works fine, I am however installing a/c soon, with which comes another small radiator to go in front of the big one. (Also, because of this a/c install id rather not spend the $100 if i dont need to hahah)
So, opinions please!
- sliq
Cracking Radiator
i think the standard radiators should do fine.. i never had a problem on my oem one apart from the top tank going very brown/on the point of cracking. no material need for the SE ones, because as you aforementioned, you won't be taking the 5 down to the track.
- Garry
Cracking Radiator
$100 for my Na top tank fitted
I must have had to pay the Sydney surcharge then.
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Cracking Radiator
If you can afford it then I see no reason why you would not get an SE radiator
Cracking Radiator
Try e-mail Simon Corston (his e-mail address is on the W.A. club website) he may still have a spare SE radiator.
Cracking Radiator
Okibi wrote:Try e-mail Simon Corston (his e-mail address is on the W.A. club website) he may still have a spare SE radiator.
Thanks okibi! he does, and its miiine
Users browsing this forum: No registered users and 24 guests
