StanTheMan wrote:didn't I hear that short toilet plumbing bend increases the torque but savagely increases the fuel usage?
i have also heard this, but i havent really noticed much difference.
broady wrote:
That said, has anyone actually measured the temperatures to see if the intake side is definitely significantly cooler than the exhaust side?
matt9111 wrote:I've attached a K&N Pod to the end of my NB8B's stock intake piping, and last week I ran my car on a dyno and only got 61.3rwkw, which is low, I don;t think its down to the Pod, because the bonnet was open and there was a gigantic fan blowing air into the engine bay. But i'm still a little suspicious, lol.
It sounds great though, lol, fuel economy is worse when I plant my foot, I think it runs a little rich with the pod under hard acceleration.
But in saying all of that, I honestly cannot tell the difference in performance from driver feel (if there is any). Worth it, if you like the cool induction sound, lol
matt9111 wrote:MXHEVN may have a point with the intake piping getting really hot...
yakob wrote:Another thing with the original pipe from the engine to air box is that the are flex points which actually create turbulance in the air flow which carries off into the engine rather than a straight flow.
Question, do you get a difference in sound just by replacing the panel filter to a k&n or something?
And if u have a CAI, does this all really matter seeing as though the air is running cold straight to the filter anyway?
I think this calculator works better for individual intake runners.broady wrote:...Using this calculator you can see that you're going to miss out on resonance points if you have too short an intake...
sliq wrote:one is HKS mushroom
