debadging.. whos done it?
Adam_NAclubman
Postby Adam_NAclubman » Thu Oct 30, 2008 1:12 pm
You sand back the area around it, get some filler, fill it, sand it, prime it, spray the panel.
Its not rocket science
Adam_NAclubman
Postby Adam_NAclubman » Thu Oct 30, 2008 2:06 pm
yakob wrote:Im talking about little touch up jobs, rather than spraying the whole panel, get me?
It will be blindingly obvious from an angle. There is a time and place for bodgy jobs, paint on a dark car isn't one of them.
I'd either live with the holes, do it properly or just not take the badge off
green_comet
Car Detailing Guru
Postby green_comet » Fri Oct 31, 2008 12:39 pm
I did my car about a year ago.. Here is how it came out.
Basically did exactly what Adam said. Pulled the badges, filled the holes, and then primed and painted.
MX5CHIC
Postby MX5CHIC » Fri Oct 31, 2008 3:49 pm
I had my NB8A resprayed Black about 6 months back, I removed every badge from it before spraying and now have fitted 2 badges with double sided tape only, an enamel badge on the nose and the original MX-5 badge which was near the number plate has been fitted under the brake lamp, it looks simple and clean.
I also used the fill and paint method on my alfa romeo but I feather sprayed clear coat on top then used 2000 grit wet and dry which gave a perfect finished job. :P
