debadging.. whos done it?
yakob
Postby yakob » Thu Oct 30, 2008 1:10 pm
Yes, and i am aware of that. However i was asking people if they had done it themselves, and how they have done it.
Adam_NAclubman
Postby Adam_NAclubman » Thu Oct 30, 2008 1:12 pm
You sand back the area around it, get some filler, fill it, sand it, prime it, spray the panel.
Its not rocket science
yakob
Postby yakob » Thu Oct 30, 2008 1:28 pm
Im talking about little touch up jobs, rather than spraying the whole panel, get me?
Caedrus
Postby Caedrus » Thu Oct 30, 2008 1:49 pm
OK, it can be done, and this is how I have done it. Please remember that this is just one method, and it takes patience.
Disclaimer
This was on a black car, I cannot make promises for your individual colour, etc.
Materials
'Green Stuff' modelling putty. You can buy this from modelling shops, and also 'Games Workshop'.
2000+ Grit sandpaper
Toothpicks
Touch up paint.
water + detergent in a spray bottle / plant mister.
Meguiar's Scratch-X
Clean terry-towelling cloth.
Method
1. Remove the badges.
2. Ensure there is absolutely no rust.
3. Plug the hole, from behind, using whatever method you can. Alternately, you can create a blob of putty and plug the hole. You may need to do this in layers, but please read point (4) first...
4. Use a toothpick to make sure the level of the putty is just below the level of the paint / panel.
5. Ensure the putty is completely dry.
6. Get a new toothpick and dip it into the touch-up paint, then allow that drop into the small, recessed, putty-filled hole.
7. Allow to dry.
8. Repeat step 7 until such a time as the paint is just above the surface of the panel / paint.
9. Sand back (and I mean this next bit) ridiculously gently, possibly using the water + detergent to ensure no burning of paint, etc.
10. Do NOT panic when the area you have sanded is very matt in appearance.
11. Use the Scratch-X & cloth to clean up any scratched area.
12. Repeat steps 6+ if you have missed any spots.
I hope this helps.
C.
Adam_NAclubman
Postby Adam_NAclubman » Thu Oct 30, 2008 2:06 pm
yakob wrote:Im talking about little touch up jobs, rather than spraying the whole panel, get me?
It will be blindingly obvious from an angle. There is a time and place for bodgy jobs, paint on a dark car isn't one of them.
I'd either live with the holes, do it properly or just not take the badge off
yakob
Postby yakob » Thu Oct 30, 2008 11:00 pm
Caedrus wrote:OK, it can be done, and this is how I have done it. Please remember that this is just one method, and it takes patience.
Disclaimer
Materials
Toothpicks
Touch up paint.
Meguiar's Scratch-X
Method
7. Allow to dry.
I hope this helps.
C.
I wish i trusted myself enough to do this.
green_comet
Car Detailing Guru
Postby green_comet » Fri Oct 31, 2008 12:39 pm
I did my car about a year ago.. Here is how it came out.
Basically did exactly what Adam said. Pulled the badges, filled the holes, and then primed and painted.
MX5CHIC
Postby MX5CHIC » Fri Oct 31, 2008 3:49 pm
I had my NB8A resprayed Black about 6 months back, I removed every badge from it before spraying and now have fitted 2 badges with double sided tape only, an enamel badge on the nose and the original MX-5 badge which was near the number plate has been fitted under the brake lamp, it looks simple and clean.
I also used the fill and paint method on my alfa romeo but I feather sprayed clear coat on top then used 2000 grit wet and dry which gave a perfect finished job. :P
yakob
Postby yakob » Fri Oct 31, 2008 7:59 pm
I was sussing it out and my car would look amazing with no badges on the back. Anyone hosting any debadging clinics with free demonstratiions :D
Users browsing this forum: No registered users and 251 guests
