Turbo Exhaust
- Woo
- Vehicle: 10AE - Turbo
Turbo Exhaust
Who's got what on what sort of turbo and where from?
Currently I run a 2.5" on a GT30/71R and have found that I've reached the limit of the exhaust. Looking for options
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
Turbo Exhaust
3" always seems to be the standard on more powerful turbo setups.
How much power are you making with your 2.5" exhaust?
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Turbo Exhaust
HKS GT2535 on 20psi with a 2.5" exhaust.
Turbo Exhaust
Obviously a big restriction there somewhere!
Stock IHI (SE) with complete 2.5" FM system and inlet mods.
- mx52nv
- Vehicle: Non MX-5
Turbo Exhaust
THE REAL BORIS wrote:Obviously
- Woo
Turbo Exhaust
Okibi wrote:3" always seems to be the standard on more powerful turbo setups.
"Obviously" you havent looked in the Garage Okibi hahaha
Lets just say, not enough
The cast AVO dump that I have is very restrictive too. Does anyone have a 3" dump coming off an internally gated turbo on an AVO cast manifold? I've had a bit of a look and there doesnt seem much room between the firewall to fit a 3".
Bazz
- ampz
- Vehicle: NA6 - Turbo
Turbo Exhaust
I have the HKS GT2535 on the 1.6 with a 2.5 in exhaust running 8psi (boo, I'll get that EBC working this weekend).
As for the T3 is it the 5 bolt flange on the rear?
If so I have one of these that is being matted to a GT2554 on a bottom mount manifold (jeez I'm lazy though, I've only tacked together the outside primaries on the mani.
That will flow on to a 3 inch exhaust. Possibly tapering down to 2.5.
Huh?
- blackster
Turbo Exhaust
Woo wrote:Looking for options
Chasing every kw possible?
3" turboback exhaust including divorced wastegate 3" downpipe
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Woo
Turbo Exhaust
Nice bit of kit Blackster.
Looks like your turbo takes pride and place in the top of the engine bay. There is no way that that would fit and AVO setup.
If you were really chasing everything you'd be looking at a 4" with a screamer pipe, but unless the turbo is huge, it's overkill.
I like the v band adaptor idea ampz, although it takes up space that could be used for the bend. It does make fitting a heck of a lot easier though
cheers
Bazz
cheers
Bazz
- blackster
Turbo Exhaust
Woo wrote:Nice bit of kit Blackster.
I would love to say that its my exhaust, but its not. Its off a yankee MSM, work was done by Tim shore. If I was chasing big power, keeping it street legal and price was not a factor, then thats I would be looking to get.
Screamer pipe, decat and 4" . I can imagine the fun you will have, when it comes to emissions testing.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Novice1
Turbo Exhaust
Garrett T28 turbo, 2.5 inch Magnaflow Cat back exhaust.
168.3kw atw on 12 psi.
Cheers Novice1
Cheers Novice1
- Woo
Turbo Exhaust
blackster wrote: I can imagine the fun you will have, when it comes to emissions testing.
Emissions testing? ..... whats that?
Have you ever tried to get a standalone certified? Avoiding detection and saving it for the track is the key
Good numbers Novice, is that an AVO manifold?
Ampz, are you going to run the extra bank of injectors? is that what you ment by tacking on the primaries?
- PASHN8
Turbo Exhaust
Baz, what ECU are you using in the MX?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- Novice1
Turbo Exhaust
Woo wrote:blackster wrote: I can imagine the fun you will have, when it comes to emissions testing.
AVO stage 2 manifold, 550cc injectors, plus a few other goodies.
Cheers Novice1
- ampz
Turbo Exhaust
Single injectors at the moment. 370cc on 6psi atm (the electronic boost control died)
I'm making a bottom mount manifold using the flange off the original extractors (1.6).
I've put about 2 hours into it now (started 2 months ago)
I've tack welded in spots the primary bends off the manifold heading down to the collector. That's it!
When it's finished (hopefully before the car is extinct)
I'm hoping for it to look like this
Huh?
Users browsing this forum: No registered users and 220 guests
