Fire Extinguisher bracket for NB8C
PASHN8
Postby PASHN8 » Fri Oct 24, 2008 2:48 pm
Chaps,
Since the harness is done, I now need a nice fire extinguisher bracket to suit my SE, where is the best place to source one? Preferable sitting in front of the passenger seat, but open to suggestions?
Dino.
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
irwin83r
Postby irwin83r » Fri Oct 24, 2008 8:49 pm
go to bunnings and buy a sheet of alloy checker plate and an aproved extinguisher.
very easy to make. i made one for my self and a couple of friends. just a rectangle with two of the corners chopped off and afew holes in it for pop rivets and for the seat mount bolts to go through.
the biggest drama is getting longer bolts for your seat ad the exrat width of the plate makes the seat bolts in my opinion not engage as far as id like. i bought some replacement bolts that were afew mm longer and of a 8.8tensile fairly cheap... not carried by bunnings or most other hardware stores. i got mine from an industrial supplier we use at work GRQ in wingdang.
i post up some pics if you like. havent got a template anymore unfortunatly.
Alex
Postby Alex » Fri Oct 24, 2008 9:37 pm
here is mine, but it's infront of the passenger seat, drivers side would be just as easy.
I just used some cardboard to make a template, 3mm aluminuium, cut to size, drill some holes, rivets for the bracket and wala
(also some wrinkle paint used)
tuned_to_fly
Postby tuned_to_fly » Sun Oct 26, 2008 6:33 pm
The VIC MX-5 Club sell brackets and longer seat bolts for $40 or so. Works perfectly and I covered mine in felt so you hardly notice the bracket against the carpet.
PASHN8
Postby PASHN8 » Mon Oct 27, 2008 11:45 pm
Thanks guys, looks like a good option for DIY :)
tuned - I have tried in vain to buy a Club Mount through a view avenues so far, but it seems no one wants my money :(
- 2005 MX-5 SE
irwin83r
Postby irwin83r » Wed Oct 29, 2008 7:27 pm
PASHN8 wrote:Thanks guys, looks like a good option for DIY :)
g's if no one else wants it and you really have to give it away ill take it :mrgreen:
wun911
Postby wun911 » Wed Oct 29, 2008 9:34 pm
but man you need cams to get on the track need to be memeber to get cams
could go the cheaper one but can only drive on certain tracks but then you dont need to be member of a club....
was thinking of getting one from the club but they are friggin heavy man im sure if you fab your own it can be lighter.
every ounce counts
Postby Okibi » Wed Oct 29, 2008 9:48 pm
Keep in mind you've got a 1kg+ weight attached, better to use a steel plate than weak light aluminium.
cshaks
Postby cshaks » Sun Nov 02, 2008 9:53 pm
If you're handy with carbon fibre...... or have a mate who is.... ( like me)
SOLD: '95 NA8 White with custom tan leather. BD bar, King Springs, 15" NB alloys.
Now driving a Mazda6 luxury sports.
PASHN8
Postby PASHN8 » Fri Nov 07, 2008 1:19 pm
Thanks for the advice guys :)
I pose the question, can anyone get me one of the MX-5 club extinguisher/bracket combo's? Would preferably like to get it in the next 2-3 days and can pickup anywhere in Melbourne?
- 2005 MX-5 SE
PASHN8
Postby PASHN8 » Mon Nov 10, 2008 5:14 pm
Success!!!
- 2005 MX-5 SE
Return to “MX5 Motor Sport”
