front numberplate custom mount
marcusus
Postby marcusus » Sun Oct 26, 2008 9:09 pm
Alfadog wrote:Why you'd want to stick the numberplate in front of the air intake is beyond me... :?
You mean radiator? I don't know of too many 5's that come with the air intake in the grille without modifications...
Meanwhile, although it's a bit of a bad angle, how about a little bit of this:
I bent my factory plate around to sit it there. Had to drill a couple of new holes too, but it's only a number plate bracket, so no big deal there. The bracket is suprisingly malleable (from what I remember anyway... did this like a year and a half ago or so).
yakob
Postby yakob » Sun Oct 26, 2008 9:15 pm
ill just put some holes in it :D
StanTheMan
Postby StanTheMan » Sun Oct 26, 2008 9:15 pm
:lol: :lol: :lol: :lol:
thats priceless
yakob
Postby yakob » Sun Oct 26, 2008 9:16 pm
your a legend, thats what i want! looks so much better, because the nose is a bit pointy on that nb, it looks odd with a numberplate sticking out. and your right. i think the radiator will be fine haha.
so u used the original bracket?
marcusus
Postby marcusus » Sun Oct 26, 2008 9:34 pm
yakob wrote:your a legend, thats what i want! looks so much better, because the nose is a bit pointy on that nb, it looks odd with a numberplate sticking out. and your right. i think the radiator will be fine haha.
Yep. Basically I bent the prongs downwards, then drilled holes so the plate sits in the mouth a little bit more. If you use the standard holes, the plate sits out at the distance of the nose, because that's obviously where the original bracket needs to go. I did have to drill new holes for the actual plate too because the holes were upside down once I bent it.
yakob
Postby yakob » Sun Oct 26, 2008 9:51 pm
so you bent the plates downwards. i get that part. but what did udrill?
marcusus
Postby marcusus » Sun Oct 26, 2008 10:13 pm
yakob wrote:Yep. Basically I bent the prongs downwards, then drilled holes so the plate sits in the mouth a little bit more. If you use the standard holes, the plate sits out at the distance of the nose, because that's obviously where the original bracket needs to go. I did have to drill new holes for the actual plate too because the holes were upside down once I bent it.
so you bent the plates downwards. i get that part. but what did udrill?[/quote]
I drilled new holes for the plate to be mounted to the bracket, and I drilled new holes for the bracket to sit further back in the mouth.
If you're gonna bend your original bracket, you'll see what I mean. Just be sure to have a metal drill the size of the bolts of the number plate holes and the bracket holes handy :P
yakob
Postby yakob » Sun Oct 26, 2008 10:21 pm
If you're gonna bend your original bracket, you'll see what I mean. Just be sure to have a metal drill the size of the bolts of the number plate holes and the bracket holes handy :P[/quote]
i have an entire arsenal of tools.
oh gosh im so excited, before everytime ithough of the finish line i would always tell myself to forget it, but now its closer, i can taste it and ican definately see it happening atleast by december, world look out!
Adam_NAclubman
Postby Adam_NAclubman » Mon Oct 27, 2008 8:45 pm
Alfadog wrote:This is what it looks like on an NA.
Fail
It's sitting back on an angle in the photo because I'd just done a country run during which I definitely did not do 100mph. I normally adjust it so it sits with the bottom ever so slightly forward of the top
This is how it normally is, its just the other photo is clearer
Take the bracket off and run cable ties from the holes in the inside of the bar that the bracket mounts to, through your plates, then zip them up. Don't do them up really tightly.
Might also pay to flush your radiator first. I havent had any problems with overheating since I put mine in the mouth (temporarily) about....... 2 years ago now maybe :oops:
yakob
Postby yakob » Mon Oct 27, 2008 10:34 pm
haha i absolutely love the cable tie idea :D
its good to know there are people out there like me who are clever, and like to cut corners but still achieve maximum results.
Adam_NAclubman
Postby Adam_NAclubman » Mon Oct 27, 2008 11:03 pm
yakob wrote:its good to know there are people out there like me who are clever, and like to cut corners but still achieve maximum results.
Wow, thanks for the compliment RogerC.
You could also do an offset mount
yakob
Postby yakob » Mon Oct 27, 2008 11:16 pm
loving the tuna can touch..
this is the world of improvised construction. i almost never buy things for projects, i just use things laying around..
call me cheap or lazy it works! and most of all its fUN!
Adam_NAclubman
Postby Adam_NAclubman » Mon Oct 27, 2008 11:28 pm
When a design works amazingly well do you keep the details to yourself?
yakob
Postby yakob » Mon Oct 27, 2008 11:40 pm
Adam_NAclubman wrote:When a design works amazingly well do you keep the details to yourself?
no, unless its worth a potential 12mil through patenting and marketing..
i love to give my share of advice when it comes to diy.
Matty
Postby Matty » Tue Oct 28, 2008 10:37 pm
you want cheap? how about no bracket at all?
double sided tape: http://mattysmx5.blogspot.com/2008/07/b ... black.html
Users browsing this forum: No registered users and 249 guests
