Clean Headlights.
yakob
Clean Headlights.
Postby yakob » Fri Oct 24, 2008 5:24 am
always looking at my headlights they look quite foggy..
i was wondering if theres a way to polish them from the inside so they come up as new.,
and idiots guide would be nice.
Clean Headlights.
Postby Mr Morlock » Fri Oct 24, 2008 10:00 am
You can polish them with car polish and this works very well but do not over do it with a heavy cut. The polycarbonate lenses are coated at time of manufacture but they tend to deteriorate with time and weathering.
philz
Wheel guru
Clean Headlights.
Postby philz » Fri Oct 24, 2008 10:22 am
mothers plastic polish
Clean Headlights.
Postby Jeo » Fri Oct 24, 2008 10:29 am
philz wrote:mothers plastic polish
+1
Clean Headlights.
Postby bruce » Fri Oct 24, 2008 10:48 am
Inside?
Clean Headlights.
Postby sliq » Fri Oct 24, 2008 1:12 pm
on NB's, you'll have to rip off the front bar to clean the lights from the inside.
Clean Headlights.
Postby Mr Morlock » Fri Oct 24, 2008 1:46 pm
You clean the lense from the outside. The lense is hot melt glued to the housing.
GP
Clean Headlights.
Postby GP » Fri Oct 24, 2008 5:49 pm
Brasso works a treat :D
Graham
16bit
Vehicle: NB8A - Supercharged
Clean Headlights.
Postby 16bit » Fri Oct 24, 2008 8:01 pm
going to give mine a go with micro fibre this weekend.
irwin83r
Clean Headlights.
Postby irwin83r » Fri Oct 24, 2008 8:43 pm
+1
+2
on the outside
PUR157
Clean Headlights.
Postby PUR157 » Fri Oct 24, 2008 11:01 pm
Just make sure you don't jump straight to the most abrasive compound you have... I've read that it's best to work your way up to consecutively rougher compounds if you find the finer ones don't work... coz then you'd just spend the rest of the day polishing back the swirls
Oneness of Man and Machine
yakob
Clean Headlights.
Postby yakob » Sat Oct 25, 2008 4:15 am
sliq wrote:on NB's, you'll have to rip off the front bar to clean the lights from the inside.
is there a tutorial anywhere? coz im sure most of the grime is on the inside. but i cnt get to that anyway can i.
Clean Headlights.
Postby sliq » Sat Oct 25, 2008 9:00 am
from big forum
Clean Headlights.
Postby Mr Morlock » Sat Oct 25, 2008 12:26 pm
Gents trust me- this is just a case of applying a light polish to a cloth rub on and rub off- apply again if not satisfied- but do not rip it into it- you do not want to completely remove the unseen hard coating on the lenses which provide long term life. I recently did this on badly weathered headlamp lenses on a Festy and the job was done in 5 minutes. It is the same process as polishing your paintwork. As an aside I have often seen taillight lenses buffed to remove marks in OE manufacture and it recovers otherwise reject parts. Too easy they say.
yakob
Clean Headlights.
Postby yakob » Sat Oct 25, 2008 1:11 pm
Mr Morlock wrote:Gents trust me- this is just a case of applying a light polish to a cloth rub on and rub off- apply again if not satisfied- but do not rip it into it- you do not want to completely remove the unseen hard coating on the lenses which provide long term life. I recently did this on badly weathered headlamp lenses on a Festy and the job was done in 5 minutes. It is the same process as polishing your paintwork. As an aside I have often seen taillight lenses buffed to remove marks in OE manufacture and it recovers otherwise reject parts. Too easy they say.
i always just wash the headlights as i wash the rest of the car, soap and rinse. but i noticed that they seemed dull on the inside. can be fixed?
Users browsing this forum: No registered users and 268 guests
